calculating help please - Car Audio Classifieds!
Old 02-01-2009, 02:06 PM
Snwbrdr1's Avatar
0/11 sssss1220
Default calculating help please
Does anyone have software or know the correct way to add up cu.ft. in my enclosure?
There are actually two lengths of vent internal to the box.
My T1 12" woofer displacement is 0.08.
H-14" -1.5"
W-36" -1.5" - another 1.5 due to the two thicknesses of the vent
D-13.5" -1.5" -another 0.75 because the front alone is 1.5 plus the back is 0.75
Port
H-12"
W-2"
L-10.25"
Can you tell what the hz. would be also?
Thank you for your time and input.
Last edited by Snwbrdr1; 02-01-2009 at 02:07 PM. Reason: forgot to add information
Old 02-02-2009, 07:03 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Can you draw this to help me understand?
This part confuses me
/ CAAA Member #2 /
Old 02-02-2009, 07:06 PM
Snwbrdr1's Avatar
0/11 sssss1220
My buddy gave me the box and emailed these specs. The vent has one slot in the front and inside has another slot like a maze? make sense? IDK
Old 02-02-2009, 07:11 PM
SPY SPY is offline
0/11 ssss10192
you mean something like this?
/ CAAA Member #2 /
Old 02-02-2009, 07:16 PM
Snwbrdr1's Avatar
0/11 sssss1220
yes without that last wall. I know its a crude example
Old 02-02-2009, 07:20 PM
SPY SPY is offline
0/11 ssss10192
so the port has 3 sections that are 12"h x 2"w x 10.25"l
/ CAAA Member #2 /
Old 02-02-2009, 07:22 PM
Snwbrdr1's Avatar
0/11 sssss1220
yes
Old 02-02-2009, 07:23 PM
MC AUDIO's Avatar
0/11 sssssss51
this site is pretty helpful http://www.the12volt.com/caraudio/boxcalcs.asp#rec
Old 02-02-2009, 07:24 PM
Snwbrdr1's Avatar
0/11 sssss1220
ok thank you
Old 02-02-2009, 07:28 PM
No, I'm not dead
0/11 sssss8128
Here it is as simply as I can put it... the area up to the beginning of the port is your enclosure. There's no need to calculate anything past the port as it's removed from the enclosure volume anyway. Measure from the wall to the inside of the port (from right to left in your picture) and where the left walls are offset simply add both measurements (say one is 30" and the other is 33") then divide the total in half to get a rough average for the total width of the box interior. then multiply that by 12.5 X 12 and divide it by 1728 to come up with the volume in CU Ft.
[COMPLEX] Properly Calculating Vent Length When Using Multiple Vents? danteBirosel Tutorials & Quick References 0 11-12-2008 01:48 PM
