aero or slot? - Car Audio Classifieds!
Old 11-04-2010, 12:11 PM
Ajax_6154's Avatar
i want more bigger db's
0/11 sssss2369
Default aero or slot?
well im designing a box for 2 12's not sure which ones yet possibly ( dc xl's, dd3512's, something like that) with around 2-3k i have a few designs in my other thread but its not the same so i started this one. Box will be around 5 ft3 max (can go smaller) it will be a Daily Driver no comps but plenty of demos.
1. What should i tune to?
2. 2 3" aeros, 1 6" aero, or a 3 inch slot port, or any other suggestions
Vehicle: 2011 VW GTI Autobahn
Deadning: 50sq ft of AT 60, Front Stage: CCX65 on a 1000c4, Sub: Eminent Audio EA1000 10's in 4.9ft3 at 35hz on a BC3500d at 1ohm
i dont like 12's they cant hit the lows like 10's
Old 11-04-2010, 12:13 PM
skmfkr's Avatar
0/11 ssssss791
i did 3cf net with 1 6" aero my 2 12" xl. i think you would be better off with the xl's seems to me that dd/aq subs like big boxes. how is your box now?id guess like subs facing forward or down and port to the side
2012 Hyundai Elantra Limited
2 15" DC XL's + RD D9
AQ4X90 + 15 IA DP 4 sale
Old 11-04-2010, 12:26 PM
Ajax_6154's Avatar
0/11 sssss2369
well im max demensions are 16wX45lX18h. it will be a center console replacement for my quad cab ram. subs up and port either up, fwd firing into the dash, or at a 45degree angle firing into the dash/roof, or if i go slot port then i can fire it at a 45degree angle back into the rear/roof
i cant post pics on this computer but ill give you this. pics on the last page
New system???
Old 11-04-2010, 12:30 PM
skmfkr's Avatar
0/11 ssssss791
well id forget the 2 3" aeros cuz its not enough port area you need 2 4" aeros atleast. a single 6" is actually more port area than 2 4". how long is the slot port you said 3" so id guess its 3" wide by how long? well you said 16w so 16w minus 1.5" from the wood on each side the port i guess is 14.5x3 so 43.5 square inches that would work.
Old 11-04-2010, 12:32 PM
Ajax_6154's Avatar
0/11 sssss2369
depending on tuning, i havent figured length out yet.
Old 11-04-2010, 12:36 PM
skmfkr's Avatar
0/11 ssssss791
i meant the port width and height not the legnth i know that depends on box size tuning and port area was just trying ot figure out your port area. does this back go from the back wall up to the dash?
528hz's Avatar
0/11 sssss1792
I always prefer aeros over slot ports.
You can get more volume with less air space sacraficed, they're easier to tune, less weight, and I have NEVER, EVER, had any port noise from any of the aero ports I've used.
Old 11-04-2010, 12:38 PM
Ajax_6154's Avatar
0/11 sssss2369
guess i was confused
in this case the box goes from up against the rear seats all the way touching the dash. port would be 3x14x?
Old 11-04-2010, 12:39 PM
skmfkr's Avatar
0/11 ssssss791
yeah only problem with aeros well two actually is trying to fit your subs and the port on the same baffle. slots are a little easier since you can change the shape of them. and also having enough depth for the aero since you cant bend them. but yeah they do save alot of space which is why i went with a 6" aero for my 2 12s box since the reason i wanted to run 2 12s from 2 15s was to have more room in the back
Old 11-04-2010, 12:40 PM
Ajax_6154's Avatar
0/11 sssss2369
im actually finding that i get port noise in my wifes box right now around 35 hz, tuned to 34/45 with a 3"aero box is 2.39net
4 HX2 10's in a Mini, Slot or Aero ports david in germany General Car Audio Discussion & Questions 8 04-08-2010 01:55 PM
Slot ports vs aero ports? 87linkin General Car Audio Discussion & Questions 6 01-16-2010 04:09 PM
Anyone Ever Seen A Slot Ported..... only126db General Home Audio/Video 6 12-08-2009 05:23 PM
Slot port and BBP craiggus365 General Car Audio Discussion & Questions 20 05-22-2009 02:40 PM
