sonotube as a port? - Car Audio Classifieds!
Old 11-06-2010, 01:48 AM
0/11 sssss1780
Default sonotube as a port?
anybody using/used these? Its 7 bucks for an 8" builders tube and the show is getting to close for comfort i need to do something pretty quick.
Old 11-06-2010, 01:53 AM
0/11 ssssss408
yea, i use a single 10" that we have sitting around work for shipping blankets for our komori press in, just do some glassing to it to stiffen it up and flare it if you can
Old 11-06-2010, 01:54 AM
Duran's Avatar
0/11 ssssss285
It'll work well, depending on the material you may need to resin the inside for strength
Old 11-06-2010, 01:55 AM
0/11 sssss5305
resin will add very little strength. do the outside of the tube in resin/glass mat and you'll be able to stand on when it's laying on it's side. I did 2 10" sono's for an enclosure with 2 21" DP's a while back...
Old 11-06-2010, 01:58 AM
0/11 sssss1780
Ash Grove 8 in. Form Tube AG - 489.08.04 at The Home Depot
" + title + "
Heres two links the ones i found.
To flare i would just cut, bend, and glass?
Old 11-06-2010, 01:59 AM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
works just dandy. best way to use on and secure it to the box would be take the side the port will be on. using a jasper jig and a 1/4" upcut bit plunge to about 1/2" deep notch. make sure you measure the inside diameter and outside diameter of the tube. once done with the circular groove use gorilla glue inside the notch slide the sonotube inside let it dry. then using a flush trim bit with bearing on the bottom trim out the circle. viola DONE!
SHABAM
Old 11-06-2010, 02:01 AM
0/11 sssss1780
Sweet guys thanks a ton. I was worried for a moment
Old 11-06-2010, 02:02 AM
0/11 ssssss408
yea my b, i never use resin without glass so i forgot to say use it, could pick my box up with it with subs in, weighed about 300lbs, all i did was wrapped one solid piece of glass mat corkscrew style all the way down it.
Old 11-06-2010, 02:06 AM
0/11 ssssss408
" + title + "
yea pretty much, just make sure all your flares are equal, i cut mine about every 2 inches, got the flares all looking similar, poked holes in the end of each tab and top of the tube, tied off with fishing line, string, whatever; set on wax paper and glassed/resined, needed slight amount of bondo work to be perfect but was pretty much free so yea......
Old 11-06-2010, 02:09 AM
0/11 sssss1780
cool ill buy some resin and glass mat. maybe another container of bondo. can never have too much of it lol
Help with a BP, slot port or square port for 2nd row 4th order bandpass wall 46panel General Car Audio Discussion & Questions 7 08-24-2010 09:32 PM
Sonotube port question?? tez4life General Car Audio Discussion & Questions 6 07-10-2010 03:17 PM
SONOTUBE enclosure... how would it sound.... Vaginatarian General Car Audio Discussion & Questions 12 04-19-2010 05:54 PM
Home Theater Sonotube Enclosures calikid3820 Car Audio Trader (WTT) 4 01-07-2010 03:56 AM
