PSI, DC, Kicker, ported VS 4th order - Car Audio Classifieds!
Old 11-07-2010, 01:22 AM
0/11 sssss4519
Default PSI, DC, Kicker, ported VS 4th order
Trying to decide what subs and box setup to use for a 2003 expedition build. Wanting a pair of 18s and either a regular ported wall in the 3rd row area, or a 4th order wall. for subs we will be using either two solo X 18s, two DC XL 18s or some PSI creations depending on what he has to offer at the time of purchase. wanting to run a Crescendo at .5 daily.
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 11-07-2010, 01:23 AM
Hertz5400LincolnLS's Avatar
0/11 sssss3029
PSI creations because you can customize them to the fullest!
SOLD TO: orangelss, SPY, 98GMC, MLyons-Jr (2x), laserred97gt, kmanian1, sotelomichael, dB-r_Electronics, EpicenterDesigns
BOUGHT FROM: SPY, fasfocus00, bones22, dbdragguy, kmanian1, TeamPSI (2x), 80inches, pioneer~saturn, sotelomichael, vic713, dB-r_Electronics, Lance_aka_64
Originally Posted by 80INCHES
just build the box and sit back and let the bass flex the $hit out of ur ride
Old 11-07-2010, 01:33 AM
0/11 sssss4519
that is my number one choice if within budget and he has the means to build them at the time of purchase. then DC and solo X as last resort. hopeing the crescendo will be enough power, if not might run a pair of audiopipe 3000d's
resolve Vas/28.32 =
result of that +1
Old 11-07-2010, 01:35 AM
0/11 sssss4519
was also thinking about two Re MX 18s
resolve Vas/28.32 =
result of that +1
Old 11-07-2010, 01:36 AM
MisterGrubbs's Avatar
0/11 sssss2358
I'd feel safer with one Crescendo haha. Ap's should give you more power, though.
Anywho, the DC is a great sub, so is the Solo X. I must admit, however, that you have no reason to use either of them for the power you have.
I vote 4th order wall IF you have the room.
David at PSI does great work.
Old 11-07-2010, 01:38 AM
0/11 sssss4519
so what subs do you recommend for upwards of 6k rms?
resolve Vas/28.32 =
result of that +1
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
i would say the xl's of the ones you listed. and as said before, run the 4th if you can, but normal ported walls are just as nice
-Youtube Channel
Old 11-07-2010, 01:41 AM
0/11 sssss4519
I am thinking we will have just enough for a 4th order. if not then ill have room for hide the batteries and do a nice amp rack.
resolve Vas/28.32 =
result of that +1
Old 11-07-2010, 01:42 AM
0/11 sssss2358
Upwards of 6k? Two Crescendos or two AP3001D's?
Anywho, if you plan on a ap3k per woofer David could make you something, The LVL4XL's or LVL5's either one should be fine and the Solo X 18's should handle that power daily with no issues as well.
0/11 sssss2358
How much room do you have/what dimensions? For just the box. Where your batteries end up = no important to me
4th order compared to ported.. jd93kid General Car Audio Discussion & Questions 10 11-03-2010 06:25 PM
2 15s ported or 4th order? rachidfunaki Enclosure Discussion & Design Construction Help 1 10-26-2010 04:55 AM
4th Order BP or Ported Parker G General Car Audio Discussion & Questions 16 11-25-2009 03:20 PM
Ported vs 4th vs 6th order bandpass sdelthon General Car Audio Discussion & Questions 20 10-19-2009 04:05 PM
