Too little port area? - Car Audio Classifieds!
Old 11-07-2010, 08:25 PM
0/11 ssssss187
Default Too little port area?
I have a 7.45 cubic foot box after displacement tuned to 32.8Hz with 3 4" aero ports. Each port is a total of 12 3/4ths in. Is this too little or should I consider eventually putting a new top on with 3 6" ports at 12.6in each? Box is for 4 10" l7's
Truck-Ford ranger extended cab
HU-kenwood kdc-x794
Front stage-3.5" infinity coax, infinity tweets, 4 goldwood 6.5's & 4 blaupunkt tweets
Front stage amp-2 Alpine 3527/alpine t220 for kick panel
Rear stage-Infinity 5x7's
Sub stage-4 10" wmd's
Box-6 cubes tuned to 32hz
Amp-Md-3D strapping a second when the $ comes
Batts-Deka 9a31/yellow top d31/yellow top d51/duralast gold starting batt up front
Big three done in 2/0ga the rest in 1/0
Alt-Db 250 amp(coming)
Old 11-07-2010, 10:07 PM
0/11 sssss1943
Its not very much port area for a box that big. 3 6" port at 12" long in that box is going to tune it in the 40's.
Old 11-07-2010, 10:16 PM
0/11 sssss2821
Way too little port area...
AKA Zachfeen
Team NWSPL
Toy
Old 11-07-2010, 10:30 PM
0/11 ssssss187
I want it tuned in the low thirties. I will end up getting more aeros eventually. I just cant afford new aeros currently.
If i added one more 12 3/4ths in 4" aero It would be tuned to 35.1Hz is that too high?
HU-kenwood kdc-x794
Old 11-07-2010, 10:34 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
More aeros/port area will raise your tuning and that would be a decent tuning for music imo if it is, infact, going to be tuned to 35Hz...
Louder. Lower.
Team Tupperware
Old 11-07-2010, 10:49 PM
0/11 ssssss187
how much port area is typical per cube?
HU-kenwood kdc-x794
Old 11-07-2010, 10:56 PM
0/11 sssss8346
Normal slot-ports most people would say 15-16ish sq inches of port per cube. But for aeros you can go considerably lower with less of a chance for port whistle/other side effects...more like 10 sq inches per cube but depends.
Louder. Lower.
Team Tupperware
Old 11-07-2010, 11:00 PM
0/11 ssssss187
okay so the port volume of each is 160 sq inches. that makes my box 7.45 after displacement of bracing and subs. Do i need to take in account for the volume of each port which would be 480 sq inches making my box now 7.17 cubes which would make my final tuning lower at 31.8hz
also each port has a total area of 185 square inches. Am i missing something that gives me 555 sq inches of port total.
HU-kenwood kdc-x794
Old 11-07-2010, 11:07 PM
0/11 sssss8346
okay so the port volume of each is 160 sq inches. that makes my box 7.45 after displacement of bracing and subs. Do i need to take in account for the volume of each port which would be 480 sq inches making my box now 7.17 cubes?
I think something went wrong when you figured port area, you want to simply find the area of the circle which is each of your ports (a 4" circle). So you want to use "area=(pi(radius x radius))" to find that...so each port will be 12.566 sq inches of port area.
Louder. Lower.
Team Tupperware
Old 11-07-2010, 11:11 PM
0/11 ssssss187
I was finding sq inches of a cylinder. You are saying find only the sq in of the opening? I am apparently dumb. Any answers to the other question? I have played around with tuning and the only other options is 2 6" which still would only be 56 sq in of port.
HU-kenwood kdc-x794
port area zero1200d General Car Audio Discussion & Questions 11 05-17-2010 08:34 PM
port area too big? dylan9999 General Car Audio Discussion & Questions 6 05-06-2010 01:14 PM
port area lantz Enclosure Discussion & Design Construction Help 10 12-27-2009 03:03 AM
How much port area? DeadlySones Enclosure Discussion & Design Construction Help 15 07-22-2009 12:45 PM
