Can someone sketch this up please? - Car Audio Classifieds!
Old 11-11-2010, 03:28 AM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Default Can someone sketch this up please?
Subs/port up with ports at the end (nearest the hatch). I don't how much space this bracing takes up but I want 2 45's, 1 in the corner feeding the ports and 1 in the adjacent corner. Also add 2-4 dowels between the subs. Then tell me how this effects tuning and airspace. Feel free to bring the total volume down to 12^3 after everything, but no less and tuning no higher than 30hz.
Old 11-11-2010, 03:37 AM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
tripple top baffle right?
/ CAAA Member #2 /
Old 11-11-2010, 03:39 AM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Whatever works as long as the cubes and tuning stays at guidelines. Perhaps I forgot the flush mount part
Old 11-11-2010, 04:25 AM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Come on Matt, help me out.
Old 11-11-2010, 04:27 AM
SPY SPY is offline
0/11 ssss10192
you don't have enough surface area for 6 12" subs and 8 4" flared ports.
Keep in mind that a 4" flared aero is 7.25" in diameter for the mounting end flair.
/ CAAA Member #2 /
Old 11-11-2010, 04:29 AM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Ok well would 3 6" aeros even be good enough? If at 12^3, it would be right at 7^2/cube.
durango sketch korey_hofer General Car Audio Discussion & Questions 35 07-06-2010 02:04 AM
Marking angles in sketch up? F3M4 Enclosure Discussion & Design Construction Help 0 01-31-2010 05:52 PM
sketch up masters korey_hofer General Car Audio Discussion & Questions 2 10-28-2009 10:35 PM
