Vent length Question - Car Audio Classifieds!
Old 02-14-2009, 08:59 PM
Gilliz's Avatar
0/11 sssssss51
Default Vent length Question
Ive been playing with diff numbers in winisd and BB6 pro. Right now in bb6, i am playing around with a 6th order. Why does the vent length increase when i increase the diameter of the port?
Thanks
Old 02-15-2009, 04:29 PM
Undadog's Avatar
0/11 ssssss810
like with any type of ported box when you increase the diameter or size of the port the length will increase also because the larger the port the more total port area you will need just like when you add multiple ports when you go from one port to two ports the length of the ports doubles
Obsidian Car Audio addict
Old 02-17-2009, 07:33 PM
Gilliz's Avatar
0/11 sssssss51
How is it possible then to fit two ports (one rear and one front chamber) in the enclosure BB recomends for the sub. VB of chamber 1 = 0.751 (Port length = 17.61 Inches with 3 Inch diameter) and VB of chamber 2 = 0.464 (Port length = 5.101 Inches with 3 Inch diameter). Just can't see fitting ports that long in the chambers.
Thanks.
Old 02-17-2009, 07:35 PM
HiloDB1's Avatar
0/11 sssss3158
You'd be better off with slot ports in this situation vs. round ports.
Old 02-17-2009, 07:38 PM
you do know that box will not sound anything like it models right
bb is modeled in half space not in car
Old 02-17-2009, 07:49 PM
Gilliz's Avatar
0/11 sssssss51
Well, im trying to learn more and understand box building. Trying to build a bandpass for this 12''. My math skills are rough, any other ideas on learning more about designing these types of enclosures would be helpful.
Thanks.
smoke vent visors *mint* splvictim20 Miscellaneous Stuff For Sale 10 01-14-2009 12:29 AM
[MODERATE] How to properly calculate port length danteBirosel Tutorials & Quick References 0 11-12-2008 02:29 PM
[COMPLEX] Properly Calculating Vent Length When Using Multiple Vents? danteBirosel Tutorials & Quick References 0 11-12-2008 01:48 PM
[BASIC] What's the formula for Port Length? danteBirosel Tutorials & Quick References 0 11-12-2008 01:46 PM
Hit & run and need to vent!!! Patrick Simmons Off Topic Chat 21 09-09-2008 08:27 AM
