Aperiodic Enclosure Anybody build these? - Car Audio Classifieds!
Old 02-27-2009, 08:57 AM
C3 Customs's Avatar
0/11 sssss2446
Default Aperiodic Enclosure Anybody build these?
I am just curious if anyone had any experience with these type of enclosures.
Def:
Very small boxes that "breathe" through a moving membrane. Both the membrane and cone can not be in the same exterior space. Either the membrane part has to be isolated by cutting a hole in the car so that it is outside, or the subwoofer has to be isolated from the rest of the trunk in a similar fashion to free air woofers. The "box" has to be as small as possible (ideally the membrane should be right up against the sub), since it is used only for coupling the sub and membrane. Aperiodic membrane configurations are very hard to design and tune, but give good frequency response and respond faster to transients, giving accurate and tight bass as opposed to boomy sound. They are not ruled by Thiele-Small parameters like other designs, so any woofer would work with the membrane.
If anyone has designed/used an Aperiodic Enclosure, any tips on construction would be very helpful. I am considering this type of enclosure due to very limited space. I know the con, complexity, and pro, transient response.
We provide our customers the only scientific approach to musical enjoyment. ."-C3 Customs
Mobile: Bravox Audio - Stetsom - Arc Audio - Second Skin - RE Audio - Clarion - DLS - German Maestro-Bazooka
Home: Onkyo - BSA Audio - Denon - Sony - Niles Audio - DLS - Sherbourn-Velodyne-Jamo
Computer: AudioEngine
832.695.3513
Old 02-27-2009, 10:13 AM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
Maybe an isobaric would be easyer?
Proud Member of CAAA!
Old 02-27-2009, 10:20 AM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
I have never tried one, but it seems like it would be similar to an IB in terms of the install work that needs to be done and then just add a box that fits around the motor and basket and add the membrane.
I'm pretty sure Parts Express sells the membrane if you can't find it elsewhere.
/ CAAA Member #2 /
Old 02-27-2009, 10:22 AM
C3 Customs's Avatar
0/11 sssss2446
With a name like c3 customs when are you run of the mill... I will look into part's express and see what I can find, thanks...
832.695.3513
Old 02-27-2009, 10:36 AM
Slam's Avatar
I slam
0/11 sssss3772
friend of mine use to build these back in the day. sounded good back then but its hard to remember
No, I'm not dead
0/11 sssss8128
PE has aperiodic vents.
Old 02-27-2009, 02:54 PM
0/11 sssss1560
Interesting product, to bad there isn't more specifics on it.
Old 02-27-2009, 03:03 PM
Slam's Avatar
I slam
0/11 sssss3772
its been being done since the early 90's
Old 02-27-2009, 03:45 PM
0/11 sssss1560
don't you need specs on the vents?
Old 02-27-2009, 03:51 PM
No, I'm not dead
0/11 sssss8128
No, calculate your box for aperiodic loading based on the driver and use the number of vents recommended for your enclosure size.
Enclosure Build for Beatkeeper1 wasted ink Build Logs 18 02-18-2009 06:18 PM
Enclosure for MTX 9510-44 Help ProjectPechkin Enclosure Discussion & Design Construction Help 1 12-25-2008 02:48 PM
[MODERATE] How To: Learn How To Build Your Own Enclosure danteBirosel Tutorials & Quick References 2 11-12-2008 03:24 PM
[COMPLEX] Aperiodic Membranes danteBirosel Tutorials & Quick References 0 11-12-2008 02:45 PM
Not quite an enclosure but a baffle... nismos14 Enclosure Discussion & Design Construction Help 44 11-02-2008 10:56 PM
