Double checking my tuning - Car Audio Classifieds!
Old 03-04-2009, 06:46 PM
aturcotte127317's Avatar
Veteran Member
0/11 sssss3613
Default Double checking my tuning
Just double checking that this will be good for my 18" BTL:
7 cubes after disp. tune it for 47.44 hz. (4) 4" ports 5.5" long. (port displacement of 302 cu in or 0.175 Cu Ft.)[this assumes each port to have.75 inches in the wood.]
Then i was thinking interchangeable ports for my daily it would be:
still 7 cubes but tuned to 38Hz and it would have 3 ports that are 4" diameter by 7" long.
any input appreciated
EDIT: or maybe tune it to 32Hz for daily, and use 4"x11" ports
147.5 sealed on dash
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 03-05-2009, 12:07 AM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
I would go for 32-33Hz...mine's at 33Hz and it's great ...and *gasp* I have an interchangeable port wall as well I'd go it, it just opens up plenty of possibilities
Louder. Lower.
Team Tupperware
Old 03-05-2009, 07:27 AM
Veteran Member
0/11 sssss3613
hmmmm ok sounds good
But using the ports i listed are there any problems i would run into (too much/ too little port area, or something??
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 03-05-2009, 07:30 AM
0/11 sssss8346
If theyre aero ports thatd be just fine...maybe a pair of 6" aero ports if I had the choice.
Louder. Lower.
Team Tupperware
Old 03-05-2009, 07:32 AM
Veteran Member
0/11 sssss3613
i am trying to stick with 4" ports, becasue i already bought this HUGE 4" PVC
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Help with tuning :( basebalz13 Enclosure Discussion & Design Construction Help 7 02-15-2009 09:43 PM
POLL: checking on interest on possible raffle bones22 General Car Audio Discussion & Questions 50 02-13-2009 12:43 AM
help with tuning...?? aturcotte127317 Enclosure Discussion & Design Construction Help 39 02-08-2009 09:22 PM
Box tuning? 98AckCL23 Talk with the staff 2 01-13-2009 11:00 AM
port tuning? 98AckCL23 Enclosure Discussion & Design Construction Help 5 01-13-2009 01:00 AM
