Box build help needed - Car Audio Classifieds!
Old 03-06-2009, 10:17 PM
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
Default Box build help needed
what's up guys i need some help with my new box build. I have a dd 9515 15" going in a 97 acura cl. my max dimensions are 16.5 high 33 wide and 20 to 22 inches deep might could go more but rather not. i did the calcs using 20 deep at re box maker and came up with 3.7 cubes tuned at 35 would aero's be the same #'s ?. now that's with slot port design,but i wanna do aero's into the ski port would be sub back port front. My ?'s are would this box be big enough or do i need more cubes and this aero port thing confuses me how many how big and how long do they need to be aggg lol im really lost. i have a few billz i could send if someone could design one and give me a cut sheet and with specs of how big to do the aero's thanks for looking
Old 03-06-2009, 10:23 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
PM'ed
/ CAAA Member #2 /
Old 03-07-2009, 12:20 AM
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
bumpo
Old 03-07-2009, 08:16 AM
Ami Creations's Avatar
Loyal Member
0/11 sssss1064
You got Pm
Old 03-07-2009, 09:26 AM
0/11 ssssss352
ygpm foo...
Old 03-07-2009, 10:21 AM
iamamp3pimp's Avatar
0/11 ssssss661
i dont think you wanna go with that exact design.......ive never tried it though...
Robin Butler
Getting back into the swing of Bass Race after a small hiatus
Old 03-07-2009, 02:51 PM
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
why is that? the aeros would be louder than the slots right?
Old 03-07-2009, 02:53 PM
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
Ok after looking at it more and using the psp port calculator my box is 5.5 cubes fresh, take in to count the port and sub should be around 4.5 or so. Now psp says if I want it tuned at 36 using 3 4" ports they should be 14.49" straight port. Does this sound right? I'm hoping this would be way louder than a regular sub back slot port back box. So if I wanted to have a 4th port and keep it plugged and take out the port if I wanted spl would I keep it the same length? Or should I just say to heck with it make the box 33-34 wide 14 high and 22 deep with sub mounted up, and ports back or forward. That would make it 4.8 cubes before woofer and ports maybe to small.
Old 03-07-2009, 11:08 PM
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
bumpo
Old 03-07-2009, 11:36 PM
thedukey42's Avatar
0/11 ssssss724
So just to see if I understand this correctly, you want to fire the subs back and the ports forward?
I don't recommend doing that.
Secondly make sure the dimensions you have specified will actually fit once you build that box. Meaning while it may fit in the trunk, will it fit through the opening of the trunk?
I would do sub back and port back or I would seal off the trunk and fire everything forward.
good luck!
Opinion needed madmat (Fix My Speaker) 9 02-16-2009 11:53 AM
WinISD tutorial needed RollerDJ Talk with the staff 30 02-15-2009 07:49 PM
recomendations needed waresgaragestereo General Car Audio Discussion & Questions 4 12-29-2008 07:28 PM
Recone needed. RollerDJ General Car Audio Discussion & Questions 0 12-23-2008 05:25 PM
PS3 help needed. RollerDJ Off Topic Chat 21 11-10-2008 09:33 AM
