SPY and other builders, come in! - Car Audio Classifieds!
Old 03-08-2009, 10:24 AM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
Default SPY and other builders, come in!
what are SAFE ways of building smaller mdf rings. i'll admit, the way i made the ones for my MTM was not safe at all. (due to the ring being smaller than the jasper jig) how are better ways of doing one?
Proud Member of CAAA!
Old 03-08-2009, 10:26 AM
No, I'm not dead
0/11 sssss8128
Band saw and reciprocating drum sander.
Cut the inner hole with the jasper jig then cut the outer part with the band saw.
Old 03-08-2009, 10:28 AM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
How small?
Just with a jasper jig and a router you can do pretty small rings safely..
Just drill the hole for the pin, do the math to account for the .25" straight bit you should be using and cut the hole for the outside of the ring...then you can drill holes and screw/mount the center piece that youre about to cutout to a piece of plywood or something that you dont mind putting a circle into and cut the inside circle and you have your ring..with it mounted like that it's plenty safe imo and make sure the screws are slightly countersunk so your router doesnt get caught up on them
Louder. Lower.
Team Tupperware
Old 03-08-2009, 11:09 AM
0/11 ssssss120
Originally Posted by Pioneer~Saturn View Post
How small?
x2 on all of that.. A holesaw works well for tweeter holes as well.
Old 03-08-2009, 11:47 AM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
How small?
I'll have to remember this one. I was doing 7" OD and different sized ID's.
Old 03-08-2009, 12:15 PM
0/11 ssssss120
Yea, router and Jasper Jig is definitely the way to go.. You'll love how clean the end result is.
Old 03-09-2009, 11:22 AM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
Yea. That thing beats using a roto-zip any day.
Orlando/altamonte springs FL builders? nitro_freak1 Box Requests 9 12-03-2008 03:35 PM
box builders in wisconsin slammed636 Box Requests 10 09-30-2008 04:30 PM
For all you sub builders out there.... forceww General Car Audio Discussion & Questions 12 08-17-2008 04:45 PM
Attention Box Builders! Patrick Simmons Wiring, Electrical & Other Installation Equipment 0 07-17-2008 02:51 PM
