Thoughts on box for LMS-4000 - Car Audio Classifieds!
Old 03-13-2009, 01:46 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
Default Thoughts on box for LMS-4000
After viewing TC's website, here are the ideal box req for a ported 10" lms.
1.8 ft^3
3" port 21" long.
That puts me at 21hz, and a port much longer than I can really use. SO, I'm thinking something like 3" port tuned to 27hz, witch will put me at 12". That's something I can use. You guys think that would work better? If I make the box sub & port up with it being 15" tall, 12" deep, how wide would I have to be to get my 1.8 ft^3?
Proud Member of CAAA!
Old 03-13-2009, 01:59 PM
No, I'm not dead
0/11 sssss8128
Use PVC elbows in the box (the smooth curve not hard 90) and snake the port inside the enclosure. Each curve is like 9" long so you could run in 8", curve and put 4" out of the elbow and have your 21" port length. Easy peasy.
Old 03-13-2009, 02:03 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
that could work to. Would PVC work with the precision ports PE sells?
Old 03-13-2009, 02:07 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
I have done this before and didn't end up with great results.
If you want to do it you need thin wall PVC elbows and they fit pretty well with the PSP ports.
You could save a little money and just buy the PSP flairs and make the rest out of thin wall PVC.
/ CAAA Member #2 /
Old 03-13-2009, 02:12 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
That's the green PVC correct?
No, I'm not dead
0/11 sssss8128
I've done it on a couple boxes (one had 2 elbows) and both were fine. You have to make sure that your ends are perfectly square or you'll end up with an irregular surface at the joint of the bend which could make noise.
Old 03-13-2009, 02:13 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
Oh, what part of that did you do that didn't turn out well spy?
BASS_WARRIOR's Avatar
0/11 sssss1142
x2
I got some pretty bad port noise using the elbows on the box my brahma was in.
Old 03-13-2009, 02:20 PM
SPY SPY is offline
0/11 ssss10192
Originally Posted by BASS_WARRIOR View Post
x2
^^ That's the one I was talking about.
2 4" aeros with bends and port noise.
/ CAAA Member #2 /
Old 03-13-2009, 02:27 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
This is why I talked about doing 27hz. No bend needed with a 12" port. What did you have it in spy? Or did you only fondle it in the basement.
my thoughts fatpat1080 Uncensored Off Topic 44 03-02-2009 09:13 PM
Thoughts on raffle? caps General Car Audio Discussion & Questions 31 03-01-2009 06:13 PM
