MDF thickness quetion - Car Audio Classifieds!
Old 03-14-2009, 05:55 PM
jj53913's Avatar
0/11 ssssss720
Default MDF thickness quetion
Well I want to do a temp. built and I have a ton of extra 1/2" MDF from doing the walls of my garage. My question is would double 1/2 be as good as 3/4"? I ask cause I already know that this build is temp. and I have the 1/2 already and 3/4 has gone up to $34 a sheet around hear. The box is going to be around 18 cu. ft. (walled Metro) and I will use as much all-thread as I can for bracing.
Old 03-14-2009, 05:56 PM
bones22's Avatar
0/11 ssss12257
that big of a box NO
unless you have enough to do 2x or 3x thick
Old 03-14-2009, 05:58 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
indeed. hell, there are not many walls that are a single layer of 3/4. so, with that being said, i'd say at least 3 layers plus some kind of bracing.
Proud Member of CAAA!
Old 03-14-2009, 06:00 PM
jj53913's Avatar
0/11 ssssss720
it would be doubled (1") and 1 1/2 for the front. I wouldn't build that big of a box out of single half. I am half retaded on some of the stuff that I do though but not that lost.
Old 03-14-2009, 06:09 PM
Buddah_iii's Avatar
0/11 ssssss302
Hola from across the state of oregon! lol off topic but didnt know if anyone else was from oregon!
What kind of subs u gunna be putting in this wall?
Old 03-14-2009, 06:18 PM
two 1/2" sheets if done correctly won't flex as much as 3/4" or 1"
Old 03-14-2009, 06:53 PM
jj53913's Avatar
0/11 ssssss720
Well I am going to build the box and if I get enough air space there will be 2 IA 21s of a rd3250.1. I don't know if I am going to be able to make it fit but I am going to try. If not I might do just one untill its time to chop up the geo.
The wood is actully 5/8" just went and measured it, not 1/2. The stuff cost me $7 a sheet.
Old 03-14-2009, 07:03 PM
2 layers of 5/8's is even better if you screw it together right I'll find a picture of what I mean
Old 03-14-2009, 07:09 PM
2x4's are up to you just look at how it's screwed together
Old 03-14-2009, 07:15 PM
jj53913's Avatar
0/11 ssssss720
Thanks for the pic. I will take the advise and see what comes of it. I hope I can get the airspace I want
