some box design help - Car Audio Classifieds!
Old 03-14-2009, 06:55 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
Default some box design help
ok so my plans for my new box are sub up/port back
got 34" deep and thats even cutting it close, but new box is 32" so i got room for port to breathe, but box is over window line.
im thinkin about doin sub/port up so i have more room to place batts behind seats since i only have room for 1/2 batts in my corner spot.
just bought me a new amp and im sure ill need more than 2 2000s to keep up with the power.
if i got dekas, 2400s and such ima need some space.
help?
92 Ranger Walkthrough
(Under Construction)
Old 03-14-2009, 07:02 PM
what are you asking exactly for a box that's under the window line in a s10 that's gonna be hard to do with the size you need
Old 03-14-2009, 07:03 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
doesnt really need to be under window line, but as close as i can, this new design is 21? which is not bad.
Old 03-14-2009, 07:04 PM
ok well what do you want then I'm sorta lost maybe cause I'm tired
Old 03-14-2009, 07:06 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
your tired.
is sub/port up a good idea
and i need some room for batts also.
should mention box is going to be 9cubes
all with backseats still up.
Old 03-14-2009, 07:11 PM
it will work I mean it won't sound like shit or anything and unless you are going over wheel wells there is a spot on the right way in back for at least 2 batteries
Old 03-14-2009, 07:15 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
yeah i had 2 batcap 2000s there. no way dekas or D3100s can fit there. just one could.
i got some ideas if i stick with sub up/port back, but amps are goin to be on the box.
no where to make a custom amp rack.
Box Design Help... Blackout Enclosure Discussion & Design Construction Help 4 01-22-2009 06:01 PM
my design korey_hofer General Home Audio/Video 9 12-26-2008 08:58 PM
Need help with my box design thecartel Enclosure Discussion & Design Construction Help 10 12-12-2008 07:02 PM
What You Think of this Design.. s Beatz General Car Audio Discussion & Questions 16 11-22-2008 05:01 PM
Can Someone design this for me. worstenemy453 Box Requests 7 11-12-2008 06:31 PM
