Tapered/horn loaded 4th order thingamajig - Car Audio Classifieds!
Old 03-18-2011, 08:03 PM
surreal's Avatar
0/11 sssss2489
Default Tapered/horn loaded 4th order thingamajig
As always I'm bored throwing around designs. Planned on starting it tonight but dove into more ideas for my LVL2 8s.
If I have enough scrap wood Ill build it tomorrow and a log will be posted. Predicted a smooth 3db climb from 30hz to 60hz where it will be crossed. Should be flattish in-cabin.
On with the lulz.
Old 03-18-2011, 08:05 PM
Awaiting Confirmation
0/11 ssssss923
Looks nice!!
CAR: 1996 Cherokee sport
WIRE: 4 runs of 2/0
SUB: 3 NSV1 18's
AMP: 3 SAZ-3K's
BOX: 4th order wall
Old 03-18-2011, 08:12 PM
0/11 ssssss580
looking at that design...u will have a low end monster
80
Husband comes home to find wife watching food channel,
he asks " why do you watch that? You still can't cook!"
She responds "and u watch porn? and still can't make love."
i call ya wife military, cause everytime we talk its about face!!
Old 03-19-2011, 10:58 PM
surreal's Avatar
0/11 sssss2489
Just as a small update, didnt have enough wood. Trying to get some money to build it.
Considering selling these two 8s for now and picking up an Epic 10 til I can afford a second. Hmpf.
Old 03-20-2011, 12:27 AM
SketchUp Master
0/11 ssssss417
specs?
Old 03-20-2011, 11:18 AM
surreal's Avatar
0/11 sssss2489
.6 After displacement, .3, flares from 60sqcm of port to 110 at the mouth. Wouldve preferred more port but that wouldve make the box impractical due to size.
Phase response stays within 90deg all the way from 10 to 80hz. Group delay doesnt hit 16ms till it gets down to 33hz.
Should handle 1200+ watts with less than 15mm excursion at peak, with a subsonic set about 33-35. Maximum predicted SPL is about 133 on 1k at 50hz. Guessing in cabin should get it a little higher. Cant say for sure though.
Should be about all the applicable info.. box is 27.5x14x10.5 tuned to 48 I believe. Has the same sensitivity as a vented box, aside from the peak that a vented would have at tuning.
Old 03-22-2011, 08:58 AM
0/11 ssssss499
hmm, curious as to how that "front chamber" area will effect it.....never tuned a horn before....
Old 03-22-2011, 10:58 PM
surreal's Avatar
0/11 sssss2489
It isn't a horn. Just a.. flared port 4th order really. Another of my hybrid type boxes that Im sure have been done before, just you dont see done normally.
It seems I wont be able to really build it as moneys short and Im trying to move these for some SA12s or 10s. But if anyone wants one of these designs, shoot me a message and we'll talk.
Old 03-23-2011, 12:25 AM
0/11 ssssss499
yah, i saw someone doing a t-line/horn hybrid reflex port 4th order last month, but never got to see any results.... i'm curious as to how it will work out. what i was looking at was the formation of the front chamber to the right of the compression plane. i haven't seen that, but i am new to labyrinth style enclosures and curious on tuning them.....also, can you explain the front/rear chamber ratio (as in reasoning, not specs) if you don't mind?
Old 03-23-2011, 01:19 AM
surreal's Avatar
0/11 sssss2489
Link perhaps? Sounds interesting.
And It was pretty simply, what the sub(s) in particular preferred. Im not taking a guess, Im actually viewing how they respond in hornresp.
If you understand enclosures and get down the basics, I think it may be easier than most people think. Though theres still a lot of things to watch out for and needed comprehension.
Rear loaded horn math.. surreal Enclosure Discussion & Design Construction Help 5 11-08-2010 08:12 PM
Rear-loaded horn jt_buck Enclosure Discussion & Design Construction Help 3 10-31-2010 07:02 PM
horn help??? tymoto21 General Car Audio Discussion & Questions 7 08-27-2010 09:36 AM
Front Loading Horn vs 4th order MisterGrubbs Enclosure Discussion & Design Construction Help 38 09-25-2009 01:58 AM
Horn Box dak446 General Car Audio Discussion & Questions 45 02-18-2009 01:15 AM
