Torres port length? - Car Audio Classifieds!
Old 03-19-2011, 01:09 AM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
Default Torres port length?
So im using Torres Calculator and i have everything i need just confused about the length. Im using 2 4" aeros, and the port length is 14", but will each aero be 14 or is it both combined 14?
Old 03-19-2011, 03:11 AM
xpd442's Avatar
0/11 sssssss48
Each.
Old 03-19-2011, 06:05 AM
SketchUp Master
0/11 ssssss417
It'll be for each. But first recheck the needed port lengths with the psp-inc(or really any other) calc. For some reason the Torres program was giving port length based on gross volume and not net volume(only for aeros). I don't know if he got it fixed or not, but be sure to check a different source to make sure.
Old 03-22-2011, 10:40 PM
supadave's Avatar
0/11 ssssss203
its each
i never had a problem with mine, i know when i put my 12 box in with the 6inc port in its tuned right where torres says it is.
Old 03-23-2011, 12:02 AM
0/11 sssssss73
where do you put the aeroport ? under or next to the sub..and how far away ?
Old 03-23-2011, 10:49 PM
SketchUp Master
0/11 ssssss417
Originally Posted by supadave View Post
its each
Did you use the gross volume or net volume?
port length help? DB-Audio Enclosure Discussion & Design Construction Help 4 09-04-2010 06:09 PM
port length help dylan9999 General Car Audio Discussion & Questions 8 07-07-2010 02:18 AM
port length? dylan9999 General Car Audio Discussion & Questions 5 04-28-2010 07:30 AM
Box tuning and port length gclark84 Enclosure Discussion & Design Construction Help 1 01-24-2010 10:38 AM
