2 DC XL 18s Box Design - Car Audio Classifieds!
Old 03-20-2011, 07:21 AM
bre2ts's Avatar
0/11 ssssss317
Default 2 DC XL 18s Box Design
Ok let me give you all the info. I live in japan and they use the metric system for MDF so I try don't have quite 3/4 inch MDF. What they do have is 18mm MDF which is as close as I am going to get here. I drive a 1994 Toyota hilux surf (4runner). I am going to have a 270a DC Alt under the hood with an optima red top under the hood and 4 Deka 9A31s in the back. This will be powering the new DC 5K amp. I am going to be running 2 DC lvl 4 XLs 18s. I want to build a box with subs up and port towards the back tuned to 32-37hz. I was wondering if some one could help me design a box. I do not want to invest all this money and not have a properly designed box affect the system from operating at optimal level. I would appreciate any help and input.
so my problem is my max width from wheel to wheel is 34'' so not quite big enough for 2 18s but i was thinking maybe a box like this would be ok... i would need help figuring out all the dimensions necessary tune have the right tuning and cube... this is my first google sketch up so its not that great
my max dimensions
34 wheel to wheel
38 back seat to trim
17 back seat height
12 right width wheel
9 left with wheel
8 right height wheel
7 left height wheel
52 widest part of truck
Old 03-20-2011, 12:58 PM
bre2ts's Avatar
0/11 ssssss317
bump
Old 03-23-2011, 06:53 PM
supadave's Avatar
0/11 ssssss203
you could do a meade style box with a window port in the middle.
not saying that your design you have will not work but i think you may have some loading issues with it being that low.
i say go with that design myself, the only problem is gonna be figureing port but they say that port calculator on carstereo.com is pretty on but i ain't sure.
Old 03-23-2011, 07:31 PM
bre2ts's Avatar
0/11 ssssss317
I decided to drop down to 2 15s just an easier fit
Old 03-23-2011, 07:48 PM
supadave's Avatar
0/11 ssssss203
it is lol
did you get the box build for it
Old 03-24-2011, 12:05 AM
bre2ts's Avatar
0/11 ssssss317
no i am just getting everything put together and ready for when i am done with this deployment... then i don't have to wait on anything and will be able to build it straight through
Old 03-24-2011, 05:32 AM
supadave's Avatar
0/11 ssssss203
good shit man
God bless you man an thanks for your service over there. be safe bro.
Old 03-24-2011, 07:02 AM
mcintosh at asylum's Avatar
0/11 ssssss545
make sure you leave a few inches from the back window so your port can breath
2 d3100 batteries
220+ alt
4 soundstreqam t5 tarantula 15's
soundstream 2500.1 rubicon
bad [email protected]$ box thanks to Sinister David
Old 03-25-2011, 09:44 PM
bre2ts's Avatar
0/11 ssssss317
So do to size restrictions I had to go back down to 15s and I got a box designer (AMI) to help me out. This is what he came up with tell me what y'all think
Enclosure:
34 x 32 - 3 Top/Bottom
34 x 16.25 - 1 Back
32.5 x 11.75 - 1 Front
31.25 x 16.25 - 2 Sides
Port:
32.5 x 27 7/8 - 2
Port Brace:
22 7/8 x 3 - 1
Box Brace:
11.75 x 30.5 - 1
Angle:
32.5 x 2 7/ 8 - 1
7cubes @ 34hz 95.25sq in of port
Old 03-25-2011, 09:59 PM
0/11 sssssss37
Enclosure:
34 x 16.25 - 1 Back
Port:
32.5 x 27 7/8 - 2
Port Brace:
22 7/8 x 3 - 1
Box Brace:
11.75 x 30.5 - 1
Angle:
32.5 x 2 7/ 8 - 1
where did go get this program pleas reply
need another box design i pay $$ Kyle K Enclosure Discussion & Design Construction Help 8 09-28-2010 07:23 AM
new box design help??? poundstone General Car Audio Discussion & Questions 1 09-21-2010 08:56 PM
Design help levee000 Enclosure Discussion & Design Construction Help 5 01-16-2010 05:28 PM
need a design RidnClean Enclosure Discussion & Design Construction Help 13 10-21-2009 03:35 PM
E8 box design. worstenemy453 Enclosure Discussion & Design Construction Help 0 06-11-2009 08:30 PM
