Best choice in a ext. cab truck? - Car Audio Classifieds!
Old 03-16-2009, 01:42 AM
0/11 sssssss75
Default Best choice in a ext. cab truck?
I'm going to be running a 15" RD Alpha at 4.5 cubes ported how should i have my box setup hit? sub up port up? downfire? sub up port forward? anyone with experience on a ext. can tell me which would sound the best?
Old 03-16-2009, 01:50 AM
bones22's Avatar
0/11 ssss12257
stick with a smaller truck
s10
ranger
something along those lines
Old 03-16-2009, 02:05 AM
0/11 sssssss75
its a ranger ext. cab just looking for which way to run my setup
Old 03-16-2009, 02:09 AM
bones22's Avatar
0/11 ssss12257
ohhh sorry i thought you were asking which truck to use
sub/port up
sub rear/port up
sub rear/port front
sub up/port side
Old 03-16-2009, 02:11 AM
toyota thundra's Avatar
TEAM-ADDICTIVE-AUDIO JOSH
0/11 sssss1896
Sub up port up always did best for me in a X cab. There are SO MANY variables that I cant honestly say what is best.
** Team Addictive Audio **
** Team 813 Customs **
** Excessive Amperage HO Alts **
** Seismic Disturbances C.C. Central FL Chapter **
ill call la migra if she gets fake tits.
L00K Here.... IM BACK BEYOTCH!!!!!!
Ive been gone for a while and I seriously missed you guys... Glad to be back.
Old 03-16-2009, 02:18 AM
0/11 ssssssss8
sub up port up for your application. Iv done MANY variations and this does work best unless you doing a very large enclosure. I have 10 10s in my s10 firing forward and the port up
Old 03-16-2009, 11:04 PM
0/11 sssssss75
also have a sliding rear window if that helps at all
Old 03-16-2009, 11:06 PM
I would go to the junk yard and get a solid one I broke my sliding with 2 cvr 12's
Old 03-16-2009, 11:08 PM
0/11 sssss1896
The enclosure is one of the most important things, but also (material wise), one of the cheapest thigs to change. I would recommend you test sub up port up and then turn the box forward... Build another box and try again
whats the tool of choice for this? waresgaragestereo Sound Deadening & Fabrication 29 08-05-2009 07:18 AM
Where can we put subs in this truck?!? BassikInstincts General Car Audio Discussion & Questions 33 03-04-2009 12:07 AM
New HU in my truck Mr.Green Member Rides & System Pictures 5 02-22-2009 11:38 PM
My truck subtle_disturbance74464 Member Rides & System Pictures 12 10-28-2008 11:30 PM
Deck Choice RidnClean General Car Audio Discussion & Questions 8 10-16-2008 10:38 AM
