Making a Cut Sheet - Car Audio Classifieds!
Old 03-20-2011, 06:12 PM
e2theloc's Avatar
0/11 ssssss909
Default Making a Cut Sheet
Anyone know of a good program to make a cutsheet that is free?
150+ Club
Follow me on Twitter!! @e2theloc
Old 03-20-2011, 11:43 PM
Get the Torres calculator. It has pretty much everything you need and is very accurate! I'm not sure if I can link it here (it's on another forum), but if you google it it's easy to find.
Old 03-20-2011, 11:44 PM
I always use sketch up and draw my own. I just trust it more than a program
Old 03-20-2011, 11:47 PM
0/11 ssssss589
pen plus paper? a full sheet is 96x48
Old 03-21-2011, 12:49 AM
0/11 ssssss284
theres a freeware program called cutsheet
Old 03-21-2011, 01:03 AM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
correction it is 97x49
measure it
i write down the dimensions of each piece in the design then on sketchup place the pieces certain ways to which i will have the least amount of wasted wood. keeping the waste to a minimum is what its about.
SHABAM
Old 03-21-2011, 02:09 AM
0/11 ssssss284
Cut List
Cut Sheet Calculator??? Slaughterhouse General Car Audio Discussion & Questions 14 08-04-2011 05:34 PM
Can i get away with using 1 sheet of MDF? Kidthump Enclosure Discussion & Design Construction Help 3 03-05-2011 02:01 PM
Is my cut sheet right? SQL Monte Enclosure Discussion & Design Construction Help 4 06-29-2010 09:32 AM
box cut sheet MiX Enclosure Discussion & Design Construction Help 5 05-03-2010 10:21 AM
need help w/ cut sheet? SacTownBully84 Enclosure Discussion & Design Construction Help 8 04-12-2010 09:00 AM
