Port Calculator - Car Audio Classifieds!
Old 03-21-2011, 10:38 AM
Matt3824's Avatar
0/11 sssss3754
Default Port Calculator
When your using a port calculator, I know that you take away the displacement of the sub, but, how can you possibly take away the displacement of the port when you dont know the volume of it until after you find the length of the port. Or do you not take take away the displacement of the port. I thought I knew how to use one until I started really thinking about it. Just a little confused.
Old 03-21-2011, 10:52 AM
Prohibited Sellers/Buyers
0/11 sssss1326
well if you know the volume your going for then you use that volume and hte port area you need. find your port length, use that to find its displacement. (dont forget to account for port walls) and add that amount to your volume when calculating it.
hope that makes since?
edit: example
like if i wanted 2 cu ft @ 30 Hz with a 2x8.75 port i would input that find my length of 20.65 multiply 20.65x2x8.75 then divide by 1728 giving you .209 cu ft. so when calculating for volume youll look for 2.21
this equationg assumes no port walls. youll want to add the wall thickness onto the width/ height as needed
Old 03-21-2011, 10:58 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
Use torres. Calculates and subtracts it automatically as you change it
-Youtube Channel
another port calculator... quaddropper General Car Audio Discussion & Questions 7 03-17-2011 09:15 PM
Port calculator confusion osmith Enclosure Discussion & Design Construction Help 4 12-27-2010 06:02 PM
Port Calculator? Josh Wahlie Enclosure Discussion & Design Construction Help 14 06-16-2010 04:16 PM
External slot port calculator? got160s? General Car Audio Discussion & Questions 7 06-06-2010 10:42 AM
port calculator? XxAkroNyMxX Enclosure Discussion & Design Construction Help 2 08-06-2009 06:51 AM
