aeroport distance away from sub / wall ?? - Car Audio Classifieds!
Old 03-23-2011, 03:08 AM
0/11 sssssss73
Default aeroport distance away from sub / wall ??
I am trying to find out how far away my aeroport needs to be from the sub and back wall. the subs are pointing up and ports to under subs. nobody seems to know any where.. any help would be greatly appreciated thanks
Old 03-23-2011, 03:17 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Ideally, you want the opening (terminus) of the port as far from the sub as you can get it, but it's not going to make that much of a difference.
You do, however need at least a diameter's distance away from the wall. So, if you have 4" ports, don't put them any closer than 4" away from the inner wall of the box.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
The Following 2 Users Say Thank You to TaylorFade For This Useful Post:
bumpin buick (03-23-2011), RapidAutoQuotes (03-23-2011)
Old 03-23-2011, 03:33 AM
0/11 sssssss73
ok great !! does it matter if the port is under and centered with the sub ?
Old 03-23-2011, 04:33 AM
lamont's Avatar
0/11 ssssss112
it should matter to much
Old 03-23-2011, 04:44 AM
0/11 sssssss73
I see from your photo it does not matter huh. you have 4 aero's...I only using 2-4" x14.5 longs on my enclosure for 2 12's
Old 03-23-2011, 05:01 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Don't sweat it too much, bro. Just fit them in there the best you can without stuffing them right up against the subs or a wall.
How big is your box? (2) 4's is cutting it close for a pair of 12's.
4x world champ
- Floyd E. Toole
Tags
aeroport, box design help, port, subs
Distance Test and Flex! ....the usual...lol twistedchild420 Car Audio Videos 6 02-22-2011 10:12 PM
1 set of ccx65's distance test dcarcstms (Crescendo) 11 02-03-2011 05:39 PM
Mids & Tweets distance test Pt.2 Juice0723 Car Audio Videos 11 01-11-2011 05:48 AM
Port distance from rear hatch jt_buck Enclosure Discussion & Design Construction Help 20 09-24-2010 02:36 PM
Best distance for ports from rear hatch? 87linkin General Car Audio Discussion & Questions 10 07-10-2010 03:02 PM
