Horn help? - Car Audio Classifieds!
Old 03-25-2011, 12:48 AM
0/11 ssssss600
Default Horn help?
Can someone shed some light on folded and tapped horn desgins?
Add me on myspace
Old 03-25-2011, 01:12 AM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
What do you need to know?
Tapped horns allow you to have a horn length 1/4 the wavelength of the lowest frequency instead of 1/2 like normal non tapped horns want and the mouth dosnt have to have the circumfrence as big as the lowest wavelength either.
There is a phasing trick that they use, and they require different subs then the ones required for a normal horn.
There are nice guides how to use hornresp, then you get experience and an understanding of it. There is a good guide at Avs forum.
Old 03-25-2011, 04:11 AM
0/11 ssssss600
Any trick/ easy way to desgin the baffle angle?
Add me on myspace
Old 03-25-2011, 09:27 PM
Novicaine's Avatar
0/11 sssss6135
You should gain experience with what compression ratio to use given the subwoofer type and size, and other parameters. Read a guide at avs forum and learn to use horn resp and that will get you going.
I am new to horns to be honest.
Theory:
Horns try to couple the subwoofer to the air, because normal boxes make it to where the subwoofer could care less about the air's coupling to the driver. The combo of motor of the subwoofer and subwoofer's parts couple their self with eachother and the air around the subwoofer does not couple good to the subwoofer because the air does NOT really affect the subwoofer's impedance like the cone and spider do, impedance is legitimate and allows coupling between things if it's matched.
So don't listen when people claim that impedance rise is bad, it is apart of the process.
Who wants to try a horn? surreal Enclosure Discussion & Design Construction Help 1 01-02-2011 02:44 AM
1 12 horn, 06 pacifica RidnClean Build Logs 29 10-06-2010 11:06 PM
horn help??? tymoto21 General Car Audio Discussion & Questions 7 08-27-2010 09:36 AM
Horn Box dak446 General Car Audio Discussion & Questions 45 02-18-2009 01:15 AM
Horn be gone!!! tater General Car Audio Discussion & Questions 6 01-18-2009 01:41 PM
