what size and hz is this box tuned to!?! - Car Audio Classifieds!
Old 03-25-2011, 06:04 PM
0/11 ssssss260
Default what size and hz is this box tuned to!?!
okay i got a box with the subs i bought it custom made. but not for my saturn vue. so im going to build a box for my car. id like it to be just like it in size.
my SUV's max width is 38" wide. i will not be using my back seat so iits not a problem. nor is the window line. i would like it subs up port back as this box is.
ok measurements 41 wide X 34.75 deep 20.25 height
Port Area: 20x23.25x8
the 2 sides of it are single 3/4 but all others are 1.5inches thick.
these are 4-15 inch treo SSi hybrids
my power ill be running with is 2 DD m3's strapped at 1ohm
Old 03-26-2011, 08:39 AM
supadave's Avatar
0/11 ssssss203
box is tuned to about 33-34
about 9 cubes after displacement of port an subs
should do good fo what you wanna do with them an thats pound the lows, good luck brother.
Old 03-26-2011, 09:13 AM
0/11 ssssss260
I need the box changed to 38wide not 41
Old 03-26-2011, 09:16 AM
0/11 ssssss260
SO. I NEED A WHOLE NEW DESIGN. OR CAN I DO 38wide by 39.75?
Old 03-26-2011, 10:39 AM
There is no question in your first post, so I'm a bit confused. I think you are trying to build a new box built to the same specs as the old one, just with modified dimentions...is that right? If so, then just keep total cubic feet of airspace equvilant...so if you shorten the width you would need to make up for it in height or depth. If this effects port area adjust as needed or extend/shorten the port length to keep tuning the same.
Old 03-26-2011, 11:31 AM
0/11 ssssss260
That's exactly what I'm trying to figure out. So say I add 2inches high and 2deep to make up for the lost measurements. I'd also like it tuned to around 31
Old 03-26-2011, 11:43 AM
0/11 ssssss260
Old 03-26-2011, 11:58 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
That's a lot of gear for someone who doesn't know how to design an enclosure. AND strapped @1? Just sayin...
Is this a burp box or what? I got ~ 15 cubes tuned to the upper 50's. Unless your port isn't 20 x 23.25 and 8" long.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 03-26-2011, 12:14 PM
0/11 ssssss260
20long x 23.25 deep x 8tall. keep your thoughts to yourself i dont have program to design this stuff
Old 03-26-2011, 12:23 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Not exactly clear there.
Do you own a calculator? You think everyone on here has some magical program to design boxes?
Get a tape measure and figure it out. Or at least be more specific about what you need help with.
4x world champ
- Floyd E. Toole
What is this box tuned to? sobe3yourself Enclosure Discussion & Design Construction Help 8 03-23-2011 11:12 PM
low tuned box korey_hofer General Car Audio Discussion & Questions 0 02-04-2011 09:16 PM
Level 4 10, 1 Cube tuned to 36 Hz or 1.26 tuned to 32?? Nebraskachevy (DC) 15 01-04-2011 11:59 PM
what is this box tuned at? rab6969 General Car Audio Discussion & Questions 2 09-17-2010 01:23 AM
So what is this box tuned to? oxsign Enclosure Discussion & Design Construction Help 11 08-26-2010 12:08 PM
