strong box 4 10s screws or staples glass or not - Car Audio Classifieds!
Old 03-25-2011, 06:09 PM
scfaust's Avatar
0/11 ssssss848
Default strong box 4 10s screws or staples glass or not
ive build boxes with screws and pre drilled and it sometimes still splits the wood and after awhile it seemed to come apart even with glue. so i built my last box with 1 inch staples and glue and glassed the inside it held up as lone as i used it. so the box im going to build now i wanted to know what u guys think the staples, with glass and a few braces swhould be ok right. i read on hear glassing dont help but it seem to seal my last box and the box didnt blow apart like the ones ive used just screws and glue on let me know how u guys feel. sorry if its been asked before
Old 03-25-2011, 06:13 PM
hifonicsviii's Avatar
Loyal Member
0/11 sssss1423
when u used screws how apart were they, what size bit u use to predrill....Ive done tons of boxes and maybe will have a split of wood or 2 but mostly on teh small pieces on ports...
I have also used braid nails and no issues but only on a single sub enclosure or the ones that have multiple cuts like the ones that go under seats of trucks
556 positive feedback from 506 users on Ebay!!!
Paypal verified ..207..since 2004
Bought from- - ShiZZZoN - pieper88 -
Sold to - super_duper - lilkman2202
Old 03-25-2011, 06:20 PM
scfaust's Avatar
0/11 ssssss848
i put the screws about a 1" apart and the bit i was told to use i dont know the size off hand so if i use a few screws with the staples u think it would be ok like screw every 3 " yea ports was the big down fall ive had too with screws
Old 03-25-2011, 06:24 PM
mcmuffin's Avatar
0/11 sssss3380
use ac ply next time u build a box. it doesnt split like mdf does. its also lighter and cheaper
*** NEW BUILD COMING SOON ***
its a secret for now
Old 03-25-2011, 06:31 PM
0/11 sssss6981
I'm running 4 10s right now and only used glue and brad nails. Box is solid and I run 4k to it
Old 03-25-2011, 06:36 PM
0/11 ssssss115
what type of glue did u use
1998 Audi A4 Quattro 1.8T
REFS: SPLLuminator, dunbar91, Merzbow, twistedchild420, psychoacoustics
Old 03-25-2011, 06:38 PM
0/11 sssss6981
Titebond II and birch wood from homedepot
Old 03-25-2011, 06:52 PM
scfaust's Avatar
0/11 ssssss848
just cheepp glue from wal mart i thought they was all the same also what do u guys think if i just drill and use them lil wooden dowls with glue insted of screw i dont know how to explane em they r used to like in dresser and stuff to hold em together but i just think they would add strength.
Old 03-25-2011, 07:08 PM
0/11 ssssss115
That's part of your problem I use pl375 it's good stuff not to expensive you can pick it up at almost any hardware store
Old 03-25-2011, 08:23 PM
SketchUp Master
0/11 ssssss417
You don't need anywhere near that many screws, just enough to suck the joint tight together while it dries. On my 60" wide boxes that I'll put in my truck, I'll use maybe 6-7 screws down the entire side, so about 8-10" spacing. I pre-drill, and can screw 2" from the corner without ever splitting the wood...I've literally never split MDF when pre-drilling and using proper spacing.
set screws gameguru1360 General Car Audio Discussion & Questions 1 12-23-2010 12:32 PM
[SOLD] Audiovox "Glass Guard" Glass Breakage Sensor toolguy420 Wiring, Electrical & Other Installation Equipment 15 09-14-2010 11:49 PM
which screws? tymoto21 General Car Audio Discussion & Questions 4 02-19-2010 09:30 AM
How strong is your box? david in germany Off Topic Chat 52 10-14-2009 02:44 PM
The Z is strong 92K1500 General Automotive Chat 28 07-29-2009 07:43 AM
