*every 1 help *need pro advice! - Car Audio Classifieds!
Old 03-25-2011, 09:40 PM
0/11 sssssss37
Default *every 1 help *need pro advice!
i was wanting to put 3 15" sundown audio nightshades v2 in a ported box.IN THE BACK SEAT OF MY TRUCK ....
THE ROOM I HAVE TO WORK WITH IS (L)3FEET x (H)3FEET x (W) 2.6 FEET IS THAT A NUFF ROOM OR COULD I ONLY GET 2 15" TO FIT
Old 03-25-2011, 09:48 PM
0/11 sssssss37
just looking 4 some advice on what i can get it there with thos measurements
Old 03-25-2011, 09:57 PM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
thats enough space for 3 nightshades for sure.
you should have no problem fitting the 9 cubes required and then some
Old 03-25-2011, 10:07 PM
0/11 sssssss37
thanks man i was on sundown site but i dident see specs u no were i can look at the specs
Old 03-25-2011, 10:09 PM
grimreper912003's Avatar
Hook me up with dat JL
0/11 sssss6190
You should have 24 cu ft gross if i did my math correctly.
Old 03-25-2011, 10:14 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
That is a ton of room...
Old 03-25-2011, 10:19 PM
SketchUp Master
0/11 ssssss417
How do you have those dimensions in the back of a truck? 30" deep?
Old 03-25-2011, 11:08 PM
0/11 sssssss37
i have a new body silverado an i have a double seat and a single seat in the back i was wanting to put the single seat back in and take the double seat out and work with more room for my new build here some picks
Old 03-25-2011, 11:09 PM
0/11 sssssss37
Old 03-25-2011, 11:16 PM
More spl's Avatar
0/11 sssss2638
Feedback Score: 29 reviews
You wanna run 3 to 3.5 cubes per sub 55 s/q inches of port per sub thats what jacob told me and thats after displacements so depending the port and the tuning is gonna let you know what you can do
this how I feel about audio
http://www.youtube.com/watch?v=8th2J3c88mU
OK need advice Austin175 General Car Audio Discussion & Questions 12 09-21-2010 01:26 PM
Advice on amp for new sub 2slotahoe General Car Audio Discussion & Questions 2 09-02-2010 05:13 PM
need advice optical General Car Audio Discussion & Questions 27 09-02-2010 01:32 AM
Advice on my next sub lslugz (PSI Car Audio) 6 05-11-2010 08:02 PM
Advice. rdaudioman1256 General Car Audio Discussion & Questions 11 11-13-2008 05:31 AM
