Enclosure volume????? - Car Audio Classifieds!
Old 03-26-2011, 08:27 PM
0/11 sssss1122
Feedback Score: 23 reviews
Question Enclosure volume?????
I am redesigning my sub bass system in my 2008 Hyundai Elantra. I currently have one SSA XCON 15" in a 4^3ft net enclosure tuned to 32hz. I am pleased with the output of the system but the enclosure is too big for my trunk area, I need more cargo space. Since I am redesigning the system I would like to achieve a smaller enclosure with more output.
For amplification I have one Crescendo 3kwp which is capable of approx. 4000wrms @ .5 ohm.
I am considering two TC Sounds Axis 12Q1. Each driver would be in it's own small sealed enclosure.
What is the optimal sealed net enclosure size for one Axis 12Q1?
Power handling: 1,000 watts RMS/4,000 watts peak Le: 8.7 mH
Impedance: 1.2 ohms per coil x 4
Re: 4.74 ohms
Frequency range: 15 - 150 Hz
Fs: 27.8 Hz
SPL: 85.4 dB
Vas: 1.41 cu. ft.
Qms: 6.30
Qes: 0.38
Qts: 0.35
Xmax: 26.5
I am no pro at enclosure calculations that's why I ask!
But based on my calculations a qtc of .707 gives me a vb of 0.4862^3ft and a f3 of 54.9hz.
Isn't that enclosure size extremely small and the f3 high? I want good low frequency extension to 20-30 hz.
Old 03-26-2011, 08:28 PM
0/11 sssss1122
I should add that I plan on mounting the drivers with the magnet out.
Old 03-26-2011, 10:26 PM
Carolina's Trunk King!
0/11 ssssss557
2.75 cube before port displacement for those with the subs on the outside of the box. Thats for the pair not 2.75 each.
Old 03-26-2011, 10:33 PM
0/11 sssss1122
Thanks but I am looking for a sealed volume.
Old 03-27-2011, 09:29 AM
0/11 ssssss557
.7-.9 with polyfill
Old 03-27-2011, 07:02 PM
0/11 sssss1122
Thanks
Old 03-27-2011, 08:21 PM
SketchUp Master
0/11 ssssss417
I wouldn't use them for sealed. The LMS-R or Exodus Shiva-X would be better options in my opinion. Not to mention that 9mH inductance in pitiful.
The Following User Says Thank You to RAM_Designs For This Useful Post:
edouble101 (03-28-2011)
Old 03-27-2011, 09:07 PM
0/11 sssss1122
Thank you for helping.
Why do you think that the LMS-R would be better than the AXIS in a small sealed enclosure? Isn't inductance irrelevent especially since I have the the subwoofer system crossed over at 60hz?
Old 03-28-2011, 02:01 PM
surreal's Avatar
0/11 sssss2489
^It shouldnt, but it still sucks.
Just go with two 10s or a single good 12. Going to be putting down some good money though for a 4" vc 12 to handle 4k if thats what youre planning.
The Following User Says Thank You to surreal For This Useful Post:
Old 03-28-2011, 02:09 PM
0/11 sssss1122
Thanks for posting your comment.
I am not considering two 10" because honestly I never heard two 10" that had good ouput. I crossed off a single 12" because it want to make use of my amplifiers full potential. So it comes down to two 12" sealed......
Best way to add volume to box MR_MT Enclosure Discussion & Design Construction Help 14 11-29-2010 08:37 PM
Volume going down by it self? davidrforbus General Car Audio Discussion & Questions 21 06-02-2010 03:14 PM
Must keep volume down ..??? Bushj311 General Car Audio Discussion & Questions 15 01-08-2010 06:48 PM
Box volume gbo559 General Car Audio Discussion & Questions 3 07-15-2009 03:51 PM
Enclosure volume forceww Tutorials & Quick References 7 08-05-2008 01:53 PM
