box for 2x AA SMD 18s - Car Audio Classifieds!
Old 03-27-2011, 03:42 PM
0/11 ssssss339
Default box for 2x AA SMD 18s
hey guys looking for best design firing subs/port in xtra cab trucks (f150) looking for spl i think my truck is peaking 50-53hz, now im doing subs up port up on driver,now i have a box 24h x 20w x 57L. port 17x13 about 5" long i was shortening it to get best freq (7" to start) biggest question would it be bettter to move subs forward and leave port where it is? or start new? also what about subs forward and long port up top against wall side to side? any help thnks, using about 10k rms, subs 18" SMDs 3500 rms no wall design THNKS
Old 03-27-2011, 08:10 PM
SketchUp Master
0/11 ssssss417
Are you easily able to push the subs to their limits in the current box? Is your box doubled up all around or not? Something tells me the box is too big and you're not able to use all of the power you have available.
The Following User Says Thank You to RAM_Designs For This Useful Post:
shaker1 (03-28-2011)
Old 03-28-2011, 11:46 AM
0/11 ssssss339
yes box is 1.5" all around 2x4 brace in middle 5/8 rod top to bottom using 4 xs 2700 and 1 ohio 240, but got rid of batts for winter getting 5 xs 3100 and changed ohio to 320a also i had only 2+ and 2- 0ga. going to put 4 and 4. and putting ply wood on roof so bass bounces off,instead of the dynamat thats on there now, direction port sub? thnks
Old 03-28-2011, 01:41 PM
0/11 ssssss339
ttt
Old 03-29-2011, 02:41 PM
0/11 ssssss339
bump
Old 03-30-2011, 05:15 PM
0/11 ssssss339
ttt
