Winisd question - Car Audio Classifieds!
Old 03-28-2011, 08:18 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Default Winisd question
I've heard that winisd is not accurate as far as port velocity goes when doing more than 1 port (especially aeros/round ports). Is that true?
Old 03-28-2011, 08:34 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
bump
Old 03-28-2011, 08:38 PM
mega fatty
0/11 sssss6008
im not sure if it does velocity at all
but i would just stick to 10-16"/cf it has always worked for me
07 mazdaspeed3
rd d9 @ .5ohm
Old 03-28-2011, 08:53 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
That only applies to regular ports though, not aeros.
Old 03-29-2011, 10:34 AM
SpeedEuphoria's Avatar
0/11 ssssss151
for aeros use 6-10"/cf, 6-8" is normally perfectly fine
From what I've seen in WinISD, it doesnt incorporate flow efficiency gained from bellmouth'd port ends, it seems to just go off of port area
'03 Dodge Stratus Coupe
'89 Dodge Spirit soon to run 10's
WiniSD Pro Ryan1126 Enclosure Discussion & Design Construction Help 6 11-08-2010 06:13 PM
WinISD question osmith Enclosure Discussion & Design Construction Help 4 11-03-2010 08:26 PM
Quick WiniSD Question tntahoe General Car Audio Discussion & Questions 16 10-20-2010 07:49 PM
winISD help coefamily Enclosure Discussion & Design Construction Help 6 01-20-2010 03:54 PM
A little fun with WinISD headshok Enclosure Discussion & Design Construction Help 11 07-25-2009 04:50 PM
