Removable Aeroport Testing ? - Car Audio Classifieds!
Old 03-29-2011, 04:02 PM
0/11 ssssss445
Default Removable Aeroport Testing ?
So I want to test the differences between 2 6 inch areos and 1 8 inch areo in the same box in the easiest fashion for a friend of mine.
Is there a simpler way than just cutting out part of the box where the port will go, then screwing on a port baffle over the hole?
I want easy testing with minimal change for when we mount the ports directly in a new same box at a later date.
Something like this
Old 03-29-2011, 10:03 PM
SpeedEuphoria's Avatar
0/11 ssssss151
thats pretty much the easiest way to do it, other then using T-nuts or similar to hold it together
'03 Dodge Stratus Coupe
'89 Dodge Spirit soon to run 10's
Old 03-31-2011, 04:35 PM
supadave's Avatar
0/11 ssssss203
i would just do one with the ring cutout for a 6in an one with the ring cutout for an 8in. or jus do like you have. have it so that each one can fit in a square like you got there an just mount each to that.
only problem you will run into is the distance from the port an the back wall.
Removable port disatvantige? Russellabt General Car Audio Discussion & Questions 2 03-21-2011 02:17 PM
new box with removable port burzendowski Build Logs 7 07-30-2010 03:15 PM
removable battery, best way to do it? Anton Miller General Car Audio Discussion & Questions 1 04-28-2010 09:45 PM
how to make a removable top assembly..... DonH General Car Audio Discussion & Questions 14 12-14-2009 02:09 PM
Removable Ports? dak446 General Car Audio Discussion & Questions 19 09-24-2009 04:21 PM
