Single 15 Box Design.Any input ? - Car Audio Classifieds!
Old 03-31-2011, 01:30 AM
xpd442's Avatar
0/11 sssssss48
Default Single 15 Box Design.Any input ?
Okay I'm going to be building a box for my Quad 1.4 La Storm X.2 15"(Essentially the same thing as the TC-3000 or Audiopulse Axis). The box will be 3.5 cubic ft net tuned to 30 hz with either 2 4" aeros or 1 6" aero. My question is should I go with the 1 6" or the 2 4" aeros?
Old 03-31-2011, 04:41 PM
supadave's Avatar
0/11 ssssss203
1 6 is better i would say. i did the 2 4's on a singla v2 alpha once an it had way more output wit 1 6 at pretty much the same freq.
Old 03-31-2011, 07:42 PM
SketchUp Master
0/11 ssssss417
A single 6" is better than dual 4".
Old 03-31-2011, 07:49 PM
1loudyukonxl's Avatar
0/11 sssss1569
can you go larger on box it kinda small for a tc3000 and a tc3000 has a copper coil a audiopulse axis has a 8 layer flat wound aluminum i would do 4.5 to 5 cubes
4 custom ia warden 18s d2
box 16.1 cubes 207 inches port 34.6
8 saz2500ds strapped at 1 ohm
21 kinetik 16v 3 dr44 alts 11 runs 1/0
high amps sax 200.4 sax 125.2
4 6.5 beyma g40s 4 10 o2 pros
tweets oldschool earthquake aka screamers
current spl on term lab 158.1 db at 37 htz no wall
Old 04-01-2011, 10:17 PM
xpd442's Avatar
0/11 sssssss48
Mine is the LA Storm X2 which has a shorter coil thats 8 layer aluminum flatwind. I can't really go much bigger and I've been told they like small boxes so 4.5-5 is pretty damn big.
Old 04-01-2011, 10:20 PM
xpd442's Avatar
0/11 sssssss48
My next question is would it be okay to bend the 6" port? If I can't bend it then I can't have it sealed off into the cabin and the box would have the sub firing into the cabin with the port firing to the side about 5" away from the side of the trunk. The sub would be on the drivers side and the port would be on the passenger.
Old 04-01-2011, 10:40 PM
SketchUp Master
0/11 ssssss417
If you can find 90° elbows that have a smooth inside, then by all means bend it. As far as box volume goes, my TC-3000 liked 3.5ft^3 much better than 4.5ft^3. Both with a 32hz tuning.
Old 04-01-2011, 10:44 PM
xpd442's Avatar
0/11 sssssss48
If you can find 90° elbows that have a smooth inside, then by all means bend it. As far as box volume goes, my TC-3000 like 3.5ft^3 much better than 4.5ft^3. Both with a 32hz tuning.
Yeah thats what I thought. They seem to model well in Unibox and winISD pretty well with a box ranging from about 3-3.5 cubic ft with a tuning anywhere from 29-33 hz. I personally like 30 hz because I listen to chopped and screwed music. Do you think there would be much of a difference between the 30 and 32 hz tuning? If I can go to 32 then I can make the port 4-5" shorter.
Old 04-02-2011, 12:13 AM
SketchUp Master
0/11 ssssss417
There wouldn't be that big of a difference from just a 2hz change in tuning.
Old 04-02-2011, 12:46 AM
xpd442's Avatar
0/11 sssssss48
Cool. Also one last question. Since I'm sealing the sub off firing it and the port into the cabin, should I do port on drivers side and sub on passenger side or sub on driver side and port on passenger?
Single 15 Box design? xpd442 Enclosure Discussion & Design Construction Help 7 03-21-2011 11:49 PM
single 9515 in a supercrew truck, need opinions on box design bigdhenderson Enclosure Discussion & Design Construction Help 85 03-08-2011 11:56 PM
single cab box design RidnClean Enclosure Discussion & Design Construction Help 34 02-07-2011 08:57 PM
Need some input. davidrforbus General Car Audio Discussion & Questions 49 10-04-2010 03:56 PM
Need input on this box design k3n12ock General Car Audio Discussion & Questions 19 02-24-2010 12:41 AM
