3 AQ15's Interchangable Port? - Car Audio Classifieds!
Old 04-01-2011, 09:49 AM
cotyballs's Avatar
0/11 ssssss258
Default 3 AQ15's Interchangable Port?
I am designing a box for three AQ 15's. My dilema is the port. I want to do a center port so I can interchange ports for tuning. The subs will be firing up in a triangle formation with the port firing toward the rear. My question for you guys is should I do one port in the middle of the box directly across from the lead sub or place two smaller ports opposite of the two base subs. Sorry if this is confusing. I can send pics if the design if needed.
Uncle Cooter Is Here To Boom
Bought From- Woofercooker, Banginkota, Twistedchild420's OPTI,
Sold To- Alexis8284
Traded With- Wes669
Old 04-01-2011, 09:23 PM
SketchUp Master
0/11 ssssss417
What kind of tunings are you wanting to do? An easy thing to do is make 2-3 ports and just plug one for daily. Doing separate inserts into a single hole is tricky because you can on;y have so much depth since you can't do a normal L-port like that. If you have the ability to do something ~25" long for daily, then my all means go that route.
Old 04-03-2011, 02:34 PM
cotyballs's Avatar
0/11 ssssss258
I just dont know where I could put the ports. The subs being placed in a triangle would have the ports going under the sub. What if I did two ports oppsite of the outer two subs and plugged one for daily. That might work. Similar to what Drek has in his mustang.
Sold To- Alexis8284
Traded With- Wes669
Old 04-03-2011, 02:45 PM
SketchUp Master
0/11 ssssss417
You can do that, but it does eat up a lot of volume. Also realize when figuring out the tunings that once you plug that one for for daily listening, the box gains that internal port volume. So you're going to have a bigger box for daily and smaller box for burps.
Old 04-03-2011, 08:22 PM
cotyballs's Avatar
0/11 ssssss258
Im glad you said that because I wouldnt have had any idea about the gain in internal port volume.
Sold To- Alexis8284
Traded With- Wes669
interchangable port help fox_racin4 Enclosure Discussion & Design Construction Help 0 09-07-2010 06:49 PM
