Box Design help - Car Audio Classifieds!
Old 04-02-2011, 09:59 AM
0/11 ssssss158
Default Box Design help
Guys, I need help on a box for 4 tc9 motored 12's. The space I have to work with is 62"w x 22"h x 27"d. Keeping in mind that I need some of the room for an amp rack. Consider this the space area of an extended cab truck for "no wall".
Here are the questions:
Subs firing front or up?
Ports firing front or up?
Individual enclosures for each sub or open for 4?
individual ports for each sub or one?
I want this for music but wouldn't mind getting some decent numbers out of it.....
If all goes well, I'll have two pf300.1 to run the subs....
Thanks
Old 04-03-2011, 01:13 AM
SketchUp Master
0/11 ssssss417
Do a common chamber and single port, subs forward and port up. You need more power as well.
box design help (9 10s) Sniper General Car Audio Discussion & Questions 3 02-05-2011 12:57 PM
need help for box design. AQ4Lyfe General Car Audio Discussion & Questions 1 10-10-2010 08:34 PM
best box design SQLbeliever General Car Audio Discussion & Questions 4 03-15-2010 10:58 PM
box design v2 RidnClean Enclosure Discussion & Design Construction Help 4 11-05-2009 08:07 PM
E8 box design. worstenemy453 Enclosure Discussion & Design Construction Help 0 06-11-2009 08:30 PM
