fighting with box rise - Car Audio Classifieds!
Old 04-05-2011, 09:39 PM
0/11 ssssss222
Default fighting with box rise
So i learned a valuable lesson about box rise with my latest build . My question is ..... Do sealed enclosures suffer from the same rise issues as ported boxes ? Also what kind of rise could you expect from a 4th order ? . Looking to get the most out of the equipment .
Old 04-05-2011, 09:49 PM
J&T DESIGNS's Avatar
0/11 ssssss791
Your going to have rise no matter what, unless it never moves. More isn't always better. I know the feeling with rise in 2 days I went from .9 to 1ohm reactive to 3.8ohms a pair and power went from 11k to 3400 it's stressful but it's part of the game.
db Revolution
J&T DESIGNS
Old 04-05-2011, 09:50 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
Sealed boxes definarely do have rise, every "box" does.
For a sealed box, when the rise comes, say around 40hz, the subwoofer can still play that frequency at the same db level as other frequencies of the same box that have a lower impedance(if you have flat box setup). Same goes for ported. You don't want to do spl sealed and it dosnt matter it is mandatory for a sealed box otherwise you will have no bass haha.
Ported you only want to worry if you are doing spl burping or spl music with a peak...
Old 04-05-2011, 10:04 PM
BassikInstincts's Avatar
Ω rise is way too high..
0/11 sssss3784
I have a ported enclosure and am battling the rise as well. Lower impedance recone is in works too.
06 Chevy Malibu Maxx LT
empty trunk
DC Power 270xp
.... so far
Old 04-05-2011, 10:09 PM
0/11 ssssss222
The van is just a daily / demo ride for the shop mainly . I just feel im skimping on the potential of the lvl 4's . clamped 1100+ watts for the pair at peak frequency . metered the van 145.5 @ 32 htz . Box seems efficient preforming on 550 watts per sub . We are walling it off soon instead of below window line and id just like to see the full output from the subs .
Old 04-05-2011, 10:15 PM
resko1's Avatar
<<< atomic at7000.1d
0/11 sssss2134
Feedback Score: 21 reviews
whats with everybody on this rise kick lately? EVERY box has rise and it changes with fifferent frequencies. Say you have 1ohm nominal. Box tuned for flat response. Meter it at say 42hz then meter it at 36. Check rise on both. I bet money if the box is flat, it will meter the same but rise will be different. Unless your burping in street class where you need all the power you can possible get since your limited on voltage and subs, rise doesnt matter. Unless for some horrible reason you rise to 30 ohms then its not a real issue. Rise controls the subs output. Kind of like a cruise control on a car. Applies gas when it needs(lower ohms) and lets off the gas when it needs(higher ohms) so that way you stay the same speed (dbs) no matter if its a up a hill, down, or flatland.
just an old fart
The Following 2 Users Say Thank You to resko1 For This Useful Post:
imlouder (06-16-2011), Novicaine (04-05-2011)
Old 04-05-2011, 10:28 PM
badmofo529's Avatar
0/11 sssss3329
thats a really good way to explain it
0/11 ssssss222
If said statement is correct this is exactly what i was wanting to know but didnt know how to ask it . So are my subs only seeing 1100 watts , when i clamped thru the different tones that was my peak output from my 3k . I just want the full potential of my subs .
Old 04-05-2011, 10:42 PM
1loudyukonxl's Avatar
0/11 sssss1569
what imp are you starting with and what are you rising to
4 custom ia warden 18s d2
box 16.1 cubes 207 inches port 34.6
8 saz2500ds strapped at 1 ohm
21 kinetik 16v 3 dr44 alts 11 runs 1/0
high amps sax 200.4 sax 125.2
4 6.5 beyma g40s 4 10 o2 pros
tweets oldschool earthquake aka screamers
current spl on term lab 158.1 db at 37 htz no wall
Old 04-05-2011, 10:48 PM
0/11 sssss1569
btw where you at in ohio
fighting gravity ftw upzaw2000 Off Topic Chat 21 09-16-2010 10:16 AM
lesnar not fighting bones22 Sports and Fitness 31 12-15-2009 05:19 PM
Fighting luises14 Uncensored Off Topic 9 10-09-2009 08:49 AM
might start fighting what do you think? kurrupt Sports and Fitness 10 09-10-2009 07:41 AM
fighting obesity korey_hofer Off Topic Chat 30 03-20-2009 01:34 PM
