sundown nightshade enclosure questions - Car Audio Classifieds!
Old 03-22-2009, 03:24 PM
allout13's Avatar
0/11 ssssss822
Question sundown nightshade enclosure questions
I figured I would make 1 thread for all of the questions I might have while designing my box.
for my first question:
How much space is needed between the bottom of the the motor and the box?
Old 03-22-2009, 03:34 PM
3/4" is usually enough
Old 03-22-2009, 03:42 PM
allout13's Avatar
0/11 ssssss822
thanks. thats good. I was going to try around 1.5"
brtnboarder3241's Avatar
0/11 sssss1595
If you have the room.. thats fine
RON PAUL 2012
Old 03-22-2009, 09:26 PM
allout13's Avatar
0/11 ssssss822
nevermind
Old 03-25-2009, 05:20 PM
allout13's Avatar
0/11 ssssss822
Are double baffles worth it?
do you lose the benefits of a double baffle with flush mount?
I think this might be the box I will build...
Old 03-25-2009, 05:29 PM
mytyeerinpie's Avatar
Elite Master Member
0/11 sssss6375
Sub up? Double baffle really helps the to from flexing and gives the 65lb sub extra support. Flush mount might be ok but personally I like to put the sub on the top baffle (of the double ) just to be sure
Posted to Monty
as it is you would have been better off with a 50cc hot pink moped with slutty on the plate
im sry bro but actions like this bring down you and the whole site....this is a place to help and or learn car audio along with selling used car audio equipment.....posting to get a rise out of ppl is not only childish it hurts caco on the whole.....
Old 03-25-2009, 05:40 PM
allout13's Avatar
0/11 ssssss822
yes, sub up. the problem Im running into is that Im afraid that if I mount it on top of the second baffle is that the surround will hit the cover over the rear hatch space. I would just take the cover off, but I may be going to college in atlanta next year and I dont want people to see my stuff. If the double baffle didnt make too much of a difference or if flush mounting it diminishes the advantages of the double baffle, I was just going to do one.
2 Sundown NightShade 15s Box Build Derrick824 Build Logs 11 07-30-2009 09:27 AM
[SOLD]FS: 15" Sundown Nightshade allout13 15" Subwoofers 40 04-09-2009 10:15 AM
Sundown Nightshade 18 hole dameter mytyeerinpie Enclosure Discussion & Design Construction Help 6 02-28-2009 07:53 AM
Sundown NightShade Pics Derrick824 (Sundown Audio) 25 02-05-2009 01:20 PM
