Port size for 2 sa-10s in 3cu. box - Car Audio Classifieds!
Old 04-11-2011, 02:42 PM
0/11 ssssssss7
Default Port size for 2 sa-10s in 3cu. box
I am putting 2 SA-10s in an extended cab Ranger. I am looking to build a 3cu. box and I want to tune it to 32Hz. They will be powered by an SAZ-2500D. This will be my first tuned box though, so I'm just looking for a little help. Max dimensions are 14"highX16"deepX50" wide. I'm just a little confused on how big to make the slot port.
Thanks guys,
Chris
E: I should also mention that this is just for daily bumping, not going to be competing.
ltr450racer690's Avatar
0/11 sssss3414
u want less of a box than that for that power, i would do 2 cubes net
AUDIOTECHIX DEALER
DLP CUSTOMS SALES REP
Old 04-11-2011, 03:00 PM
0/11 ssssssss7
Okay thanks. Too much power?
Old 04-11-2011, 03:11 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
im doin the same setup, 2 SA10s off 2500, my box is [email protected] with a 6" aero to the passenger side, i have a single cab tho.
my box is like 3.2ish gross(before any displacement)
92 Ranger Walkthrough
(Under Construction)
Old 04-11-2011, 03:20 PM
0/11 ssssssss7
Do you think I would be better off with an aero than a slot port? And this may sound dumb, but when doing a slot port is the port volume figured into the volume of the box?
Old 04-11-2011, 10:47 PM
SketchUp Master
0/11 ssssss417
You need to figure the port length by using the final volume that the subs will see, accounting for all displacements.
Port Size? Radioactiv Enclosure Discussion & Design Construction Help 2 11-10-2010 05:21 PM
I have a 9.5 cubed box for one sub want should be my port size. More spl Enclosure Discussion & Design Construction Help 8 03-22-2010 07:22 AM
Need help with port size nastyone Enclosure Discussion & Design Construction Help 2 02-20-2010 11:45 AM
Box and Port size RD HW 18 Drock040687 General Car Audio Discussion & Questions 44 11-28-2009 06:12 PM
Port Size BassikInstincts Enclosure Discussion & Design Construction Help 10 03-30-2009 07:19 AM
