i need your help guys? - Car Audio Classifieds!
Old 04-13-2011, 01:04 PM
Kingdom of Solitude
0/11 sssss1254
Default i need your help guys?
i dont have the ability to make 45s and i want some ideas on how to brace my 8.24ft^3 box. its for 2 AQ HDC315 subs in a common chamber driver side ported box MDF wood i do have a threaded rod that is 3/8 in diameter that i will be runnibg threw the box from side to side and front to back and top to bottom. with al the appropriate nuts and bolts.
Thanks in advance
Old 04-13-2011, 01:10 PM
grimreper912003's Avatar
Hook me up with dat JL
0/11 sssss6190
wooden dowels work too
Old 04-13-2011, 01:22 PM
Kingdom of Solitude
0/11 sssss1254
were at do u have a pic of them along with where you put them
Old 04-13-2011, 01:30 PM
Kingdom of Solitude
0/11 sssss1254
n e 1
Old 04-13-2011, 01:40 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Threaded rod will brace it, dowels would be used in the same way as the threaded rod.
45's are not typically used for bracing.
/ CAAA Member #2 /
Old 04-13-2011, 01:46 PM
Kingdom of Solitude
0/11 sssss1254
so i mean if i am using the steel threaded rods do i really need the wooden dowels
Old 04-13-2011, 02:04 PM
Highs On Bass's Avatar
I'm F*CKIN Sexy!
0/11 sssss2132
no if your using the all thread the wood dowels are not needed.
something else you can use as bracing is 2x4's. or 2x3's.
they do take up more airspace but its still a solid way to make bracing.
Yep... I'm an AMI NUT HUGGER>.. HE's the master of my wood
Current scores to date as of 12/5/2010:
Sealed 152.9
Outlaw 156.6
Old 04-13-2011, 02:42 PM
0/11 sssss6190
What is this bracing you guys speak of anyways
Flex = BASS right?
What do you guys think? dadydolas General Car Audio Discussion & Questions 1 01-14-2010 09:40 PM
What do you guys think of this sub? ClevelandFreeman General Car Audio Discussion & Questions 10 12-12-2009 10:41 PM
guys i need help!! Violence* Off Topic Chat 0 12-09-2009 08:18 PM
Hey guys DLP customs Off Topic Chat 5 12-08-2009 06:28 PM
Hey Guys jagon82 New Member Orientation 14 06-25-2009 09:32 AM
