Which volume to choose and Why?? - Car Audio Classifieds!
Old 04-18-2011, 08:34 AM
tntahoe's Avatar
0/11 sssss1196
Default Which volume to choose and Why??
I have an 2003 Tahoe Im about to build an enclosure for 4 15s, the specs say anywhere from 2.5 to 4 cft per sub, so im just curious to what would make you choose 2.5 over 4 or vice versa if space is not an issue, and which would give better results and why
Old 04-18-2011, 08:42 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Mainly power handling. the larger the box the less power it takes to get it loud. But also the less power the subs can handle. The smaller the enclouser the more power it takes to get loud. But also the subs can handle more due to loading and impedance rise factors.
For 4 15's I would go with 14-16 ft3 with around 150-200sqin of port.
Old 04-18-2011, 08:49 AM
0/11 sssss1250
Feedback Score: 34 reviews
Go as big as you can.
SPL-Lab REP
Want an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has more features and more support? PM me.
Old 04-18-2011, 08:53 AM
tntahoe's Avatar
0/11 sssss1196
I have more than enough amp to push them in a small or large enclosure, why so much port area ( other than to minimize port noises)
Old 04-18-2011, 08:54 AM
Ja Marcus
0/11 sssss6975
I have tested the demensions I listed and they work fine. Can you go big and shrink it done...yes. But unless your competing your just wasteing time. That size box will give you good power handling with good output.
But if you want to build it as big as you can and test test test to see what is the best by all means go right ahead.
Old 04-18-2011, 08:55 AM
Ja Marcus
0/11 sssss6975
Essentially just that. You can play around with the size a bit if you want. Maybe start at 6 or 8" and just add pieces to shrink it down a bit.
Old 04-18-2011, 08:56 AM
0/11 sssss4519
150-200'' of port for a 16cube box sounds about right. Its actually a little on the small side for my enclosures but that always depends on vehicle,power,subs,music, and space available.
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 04-18-2011, 09:02 AM
Ja Marcus
0/11 sssss6975
Figure 6" wide by 30" tall....I usually do about 12-15sqin of port per cubic foot.
Old 04-18-2011, 09:14 AM
1loudyukonxl's Avatar
0/11 sssss1569
tahoes like around 11 to 13 inches of port
4 custom ia warden 18s d2
box 16.1 cubes 207 inches port 34.6
8 saz2500ds strapped at 1 ohm
21 kinetik 16v 3 dr44 alts 11 runs 1/0
high amps sax 200.4 sax 125.2
4 6.5 beyma g40s 4 10 o2 pros
tweets oldschool earthquake aka screamers
current spl on term lab 158.1 db at 37 htz no wall
Old 04-18-2011, 09:18 AM
surreal's Avatar
0/11 sssss2489
^lol at yukon again. The car doesnt like the port, the sub does brah.
It depends what subs they are. They could be optimal in 2 cubes each for all we know, or they could be IB and want all 14 cubes a piece.
Everyone saying go the biggest you can are just talking out of their ass.
If you have more than enough power. NORMALLY go smaller, like 3 a piece. It will help power handling as well as get rid of the nasty peak around tuning from an oversized box.
How to get more volume SPLpizzaguy General Car Audio Discussion & Questions 5 03-19-2011 08:32 AM
Best way to add volume to box MR_MT Enclosure Discussion & Design Construction Help 14 11-29-2010 08:37 PM
Volume going down by it self? davidrforbus General Car Audio Discussion & Questions 21 06-02-2010 03:14 PM
Must keep volume down ..??? Bushj311 General Car Audio Discussion & Questions 15 01-08-2010 06:48 PM
Box volume gbo559 General Car Audio Discussion & Questions 3 07-15-2009 03:51 PM
