Need help with box build - Car Audio Classifieds!
Old 04-19-2011, 10:28 PM
kickerlivinloud's Avatar
0/11 ssssss162
Default Need help with box build
I was wondering if i could get some help with a box build for straight spl behind the rear seat.
The vehicle 2002 ford explorer 4 door
The equipment i will be running.
6 audioque sdc 12s
3 audioque 2200s
5 100amp a hour batteries
3 factory 130amp alternators
6 runs of 0ga 3 hot 3 neg
i would like to do subs up port back.
these are the dimensions
45"w 22"h 36"d
my last setup done 150.1db with 2 of the amps subs up port up that size with 211 sq in of port tuned to 29 htz
i would also like to know if its possible to get a 155db on burps with that equipment.
any help is greatly appreciated thanks
Old 04-20-2011, 12:18 AM
SketchUp Master
0/11 ssssss417
155db(legal) is going to be rough unless you tune higher. I believe those Exploders peak in the high 40's...so maybe try using 6" aeros and just plugging one or two for daily?
Old 04-20-2011, 04:25 PM
0/11 ssssss162
how many areos and how long do they need to be
Old 04-20-2011, 08:53 PM
Skip01's Avatar
Ladies MAN
0/11 sssss5551
Gonna be hard too get 55 legal with that power.
I was right at 53 legal with 6 12s and 2 2500s.
With 4 12s and 10k i was at 154 legal.
This was all on daily, music setups...no burp boxes.
This is my current box...waiting on recones and im gonna get more power...i should be close too 55 legal on music.
Youtube VIDz :
Old 04-20-2011, 09:34 PM
0/11 ssssss162
just added pics or my setup
Old 04-20-2011, 09:51 PM
1loudyukonxl's Avatar
0/11 sssss1569
it took me 7600 rms clamped to do a 155 at 37 so you really will need more power and my buddy vernon took him 8k with 4 12s not saying it impossibe just unlikely 153s maybe if built right but i doubt much louder cause 3600 clamped and i was doing 153.2 with 4 15s with 2 18s on 6k clamped i was doing 154.2 with 4 18s on 13200 rms clamped i was doing 156.5
4 custom ia warden 18s d2
box 16.1 cubes 207 inches port 34.6
8 saz2500ds strapped at 1 ohm
21 kinetik 16v 3 dr44 alts 11 runs 1/0
high amps sax 200.4 sax 125.2
4 6.5 beyma g40s 4 10 o2 pros
tweets oldschool earthquake aka screamers
current spl on term lab 158.1 db at 37 htz no wall
Old 04-20-2011, 09:58 PM
0/11 sssss1569
i would try using you current box and retune it to 38
Old 04-20-2011, 09:59 PM
0/11 ssssss162
so tell me what i need to do in order to reach a 155db more power,more cone,better build,different subs someboddy let me know what it takes
Old 04-20-2011, 10:00 PM
0/11 ssssss162
how much port area
Old 04-20-2011, 10:17 PM
0/11 sssss1569
155 is not a right out the box thing enless you spend a ton of money it alot of testing
CLNFREAK'S build... rebuild.... build... CLNFREAK Build Logs 43 06-26-2012 06:25 PM
S-10 truck build and blow-through build DevinG17 Build Logs 82 02-16-2011 01:58 PM
Story of my 18 build (first real build) TheAustinHenry Car Audio Videos 35 12-20-2010 12:04 AM
SPL_II's Team CACO Build Log <--- First real Build! SPL_II Build Logs 123 09-23-2010 08:44 PM
deepsilencer's new box build video designed by james(A.I),build by 99s10walled deepsilencer Car Audio Videos 1 08-30-2010 01:43 AM
