Dad Needs Help, 6.5 Box Design Needed! - Car Audio Classifieds!
Old 04-22-2011, 03:18 PM
BassikInstincts's Avatar
Ω rise is way too high..
0/11 sssss3784
Default Dad Needs Help, 6.5 Box Design Needed!
Hey guys, question for you boxy folk! My dad has a pair of these sitting around and wants to start putting together (what I think is the 4th) surround sound system in our house. This is going in his work room. He put these in some boxes he had laying around the said the highs sound nice, but he wanted to try and get a little more bass response out of them. He called me and asked if I could get a design like a subwoofer box where the port helps play into the response of the speaker. Would it work? If so, how would you build it? I would just need dimensions, I would appreciate any input! Thanks!
-Steve
Vifa A16CG-21-04 6-1/2" Coaxial Speaker w/Audax T
Accurate bass and extended high frequency response
Coaxial Audax dome tweeter
Poly cone with rubber half roll surround
"Universal" plastic-injected basket
Crossover capacitor included
4 ohm nominal woofer impedance
8 ohm tweeter
Versatile high fidelity driver featuring a coaxially mounted Audax poly dome tweeter connected through separate leads to a 2.2 uF crossover capacitor, which may be bypassed for alternative filter designs. "Universal" plastic-injected basket, mineral filled polypropylene cone, rubber surround, high temperature voice coil, and very smooth frequency response. Perfect for indoor/outdoor systems, surround sound, custom in-wall and in-ceiling, and mobile audio applications.
Specifications:
*Power handling: 70 watts RMS/110 watts max
*VCdia: 1"
*Le: 0.53 mH
*Impedance: 4 ohms
*Re: 2.9 ohms
*Frequency response: 48-20,000 Hz
*Fs: 48 Hz
*SPL: 86 dB 1W/1m
*Vas: 0.64 cu. ft.
*Qms: 2.63
*Qes: 0.85
*Qts: 0.64
*Xmax: 2.5 mm
*Tweeter crossover: 10 kHz @ 6 dB/octave
*Dimensions: A: 6-1/2", B: 5-3/4", C: 3-1/4".
06 Chevy Malibu Maxx LT
empty trunk
DC Power 270xp
.... so far
Old 04-22-2011, 05:19 PM
0/11 sssss3784
Possible Ideas?
empty trunk
DC Power 270xp
.... so far
Old 04-23-2011, 08:49 PM
0/11 sssss3784
Anything?
empty trunk
DC Power 270xp
.... so far
Old 04-23-2011, 08:59 PM
surreal's Avatar
0/11 sssss2489
Ill do a design for a few bucks if youd like. Hope you have tools to flush mount them and round over edges.. no nasty resonances wanted.
4th order design needed LivinLoud08 Enclosure Discussion & Design Construction Help 17 03-04-2011 06:01 AM
walkthrough design needed. Violence* General Car Audio Discussion & Questions 0 07-03-2010 05:18 PM
3 15" TC3000's DESIGN NEEDED ASAP jdubbau Box Requests 1 09-29-2009 02:02 PM
BOX DESIGN NEEDED ASAOP x2 DC LVL 5 18's! jdubbau Enclosure Discussion & Design Construction Help 0 07-28-2009 08:44 AM
Box design opinions needed SPY Enclosure Discussion & Design Construction Help 13 09-12-2008 02:11 PM
