1 sundown sa 15 D1 alu coil - Car Audio Classifieds!
Old 04-24-2011, 12:22 PM
chevy88caprice's Avatar
0/11 sssssss70
Default 1 sundown sa 15 D1 alu coil
OK this is the room im working with. Need help with sub box design and what kind of box to go with. Will b powering the sub with a Earthquake 2000watt @ 2 ohm. I would like it ported through the rear desk. And box tuned to about 30 or 33 hz. thanks for any and all help.
Pictures by chevy88caprice - Photobucket
Old 04-24-2011, 06:42 PM
0/11 sssssss70
anybody?
Old 04-24-2011, 07:49 PM
0/11 sssss1480
Feedback Score: 63 reviews
Can't really understand your drawing, but by some of your measurements you will def have room. I had it in a 3.2 net can't remember what it was tuned to. It was powered by my 2500 at 2 ohm. I would suggest 3.5 for you tuned to 30-33hz. It will smash the lows.
Old 04-24-2011, 08:01 PM
0/11 sssssss70
sorry cant draw for shit but i got pics u can look at if it will help
Old 04-24-2011, 08:33 PM
0/11 sssssss70
just measured one side of my trunk. please somebody help. I want to start building tomorrow
Old 04-25-2011, 02:19 PM
0/11 sssss1480
Alright, is the part where the floor goes up(closest to your back seats) 17". If it is, I would build the box to fit up in that little space, fire the sub to the rear. I would use 3 4" aero ports. If you want the ports through your rear deck you would just have to have some of it on the outside of the box.
Old 04-25-2011, 04:43 PM
0/11 sssssss70
Only 10" height behind the rear seat
Old 04-25-2011, 08:31 PM
0/11 ssssss446
go with 4-8s in that area or 2-8s ..my friend did 2-1508 DD subs in a rear deck blowthrew and it was banging... 1500rms and man no joke it was QUAKE N ... it was a monte carlo.. but loud .. he wanted to go with 2 15s blown threw back deck but ran in to problems with those crazy angles.. PWK designed my friends box and it was Crazy Loud...
Old 04-25-2011, 09:02 PM
0/11 sssssss70
But i already have 1 sa-15 and I know I can make a big box just need to know how big to build it and how to design it and with measurements. and how to tune the box using wood no areos. thanks if ur info
Old 04-25-2011, 09:24 PM
0/11 ssssss446
if i was u id get in contact with SURREAL on here he had a bad ass setup with a single 15 it was a DD but he had a saz1500 and it was BANG N ... i dont think u will be abkle to do the rear deck blowthrew with the 15 tho... but u can get a box deigned and built that will poundd like a mofo... good luck
The Following User Says Thank You to maxdout918 For This Useful Post:
chevy88caprice (04-25-2011)
Sundown Z v.2 Aluminum Coil T/S Specs sundownz (Sundown Audio) 3 11-23-2011 10:30 AM
Sundown Z v.2 Copper Coil T/S Specs sundownz (Sundown Audio) 7 07-23-2011 09:49 AM
Elevation EXE motor and a 3" Round aluminum TC coil, D.5, coil can easily handle 2k R Novicaine Car Audio Packages 7 05-04-2011 09:59 PM
Sundown SA 10 coil id/od? Dunbar91 General Car Audio Discussion & Questions 0 04-12-2011 06:20 PM
