Port Size - Car Audio Classifieds!
Old 03-28-2009, 07:55 PM
BassikInstincts's Avatar
Ω rise is way too high..
0/11 sssss3784
Default Port Size
I was hoping there was a thread stickied like this, but I see there is not. What is the calculation for tuning a port to something? Can someone help me out? What information do you need to tune it.
06 Chevy Malibu Maxx LT
empty trunk
DC Power 270xp
.... so far
Old 03-29-2009, 04:54 PM
420guy's Avatar
CACO Canuck
0/11 ssssss251
In for some learning as I am really confused how to calculate ports.
97 Cavalier dbDrag Street A - 142.7 @ 39hz
HU ~ Kenwood Excelon X-991
Front stage ~ Clarion SSS601 components
Subs ~ 2x Clarion SSW1001 10" D4
FS amp ~ Memphis 16-MC3004
Sub amp ~ Hifonics Brutus BXi2006D
Box ~ Tuned at 34.5hz separate chambers and common center slot port.
Deadening ~ B-Quiet extreme
Member #12 of CAAA
Old 03-29-2009, 09:23 PM
0/11 sssss3784
bumpity, please? are slot ports different then tube ports for tuning?
empty trunk
DC Power 270xp
.... so far
Old 03-29-2009, 09:24 PM
0/11 sssss6075
Yes and no
Old 03-29-2009, 09:25 PM
Originally Posted by terra View Post
Yes and no
yeah what he said you tune them the same way but to figure out the area it is different
Old 03-29-2009, 09:27 PM
0/11 sssss3784
well, how do you figure out area in relation to tuning?
empty trunk
DC Power 270xp
.... so far
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
Tuning a port:
4 types of tuning
A: 20-30 hz tuning is geared towards SQ
B: 31-35 hz tuning is geared towards SQL
C: 36 - 40 hz is on the brink of pure spl tuning but will typically yield decent sq with more spl.
D: 40hz + is generally for straight spl, and used with test tones going through the driver for competition purposes.
There are many good tuning calculators, some do NOT take into account sub displacement so be sure to calculate that.
Basic Car Audio Electronics has a good one located here:
The following links also helped me in choosing my port length.
Woofer Enclosures - Fraction to Decimal - Parallel - Series - Port Length and Volume Calculators
PORT Size Calculations and Formulas for WOOFER and Subwoofer BOXES (Scroll down on this site, there are two calculators)
There are also different types of ports
Slot ported, and round ports.
Slot ports tend to recduce the likelihood of port noise. They also tend to be larger boxes. Port tubes in an enclosure can be very finicky. It is a good idea to use aero ports with flared ends to avoid the issue of port noise.
With any Ported enclosure it is a very good idea to use subsonic filters at or SLIGHTLY below the tuning frequency.
Here's an example of why.... Say you have a 500 watt amp pushing a sub in a box tuned to 35 hz. Any frequencies that go through the driver below 35 hz can cause the driver to unload because below the tuning frequency there is less resistance to the motion of the driver and quite a bit less power handling. It is essentially a free-air driver below the tuning frequency. Therefore, if the driver has a low QTS, it is likely that even if the driver is rated for 500 rms, the mechanical limits will change when it is below tuning frequencies. In some cases you may be able to get away with it. So basically, just like a driver that is being used IB it would loose some of its power handling if it is not specifically made for IB use. The driver's ability to handle the full 500 watts is no longer true below the tuning frequency and you could very well destroy the woofer in that scenario.
Ported enclosures do require extra care in design and build as a ported box that is not built properly for a specific driver may cause damage to it.
Ported boxes tend to be much more efficient than sealed enclosures although this may not ALWAYS be the case. Above the tuning frequency the driver will also tend to handle more power.
The length of the port is crucial in determining the proper freq. The longer the port area/volume the lower the tuning would be. For instance in my application I have a 1.88 cu ft box with a port that is 15 inches this gives me a tuning of ~32 hz. A shorter port woud have given me a higher tuning freq. If it was 10 inches the tuning frequency would rise into the high 30's.
My Car, My Ears.
nismos14's Avatar
Super Moderators
0/11 ssss18247
Thats my writeup.
My Car, My Ears.
Old 03-29-2009, 09:35 PM
0/11 sssss1560
Good writeup!
What do you think of tuning at 25hz?
Old 03-29-2009, 09:42 PM
null_void's Avatar
0/11 sssss5915
its doable, but only w/ certain subs will u yield good results(ie: re xxx) and subs w/ low fs. why?
ps, good writeup nizzy!
What size fuse are you using? Patrick Simmons General Car Audio Discussion & Questions 29 03-19-2009 04:39 PM
What Box Size.. s Beatz General Car Audio Discussion & Questions 6 03-16-2009 01:39 AM
Sub/Size Suggestions. 350zkid General Car Audio Discussion & Questions 21 02-10-2009 08:03 AM
guess teh woofer size natisfynest Off Topic Chat 49 01-31-2009 03:52 PM
