Need help with figuring out port size - Car Audio Classifieds!
Old 05-01-2011, 11:20 AM
macisme's Avatar
Team Sundown FTMFW!
0/11 sssssss16
Question Need help with figuring out port size
I have built my box for my two solo x 18's which according to the wedge2 specs on the12volt came out to around 34cubes.. before bracing sub displacement and port. Sine around 20 cubes is about max for these subs it leaves me with plenty of bracing headroom and port size. I have walled the 18's off behind my backseat for now and will have my battery rack under the truck.. everything fits and is almost ready for final push on box build, but I need help with port length and size. Looking to tune around 36-38hertz. I have been told our trucks RF is 38 so I would like to stay around that with my tuning. Amps will be two strapped saz3000's jfyi. Ty for any help u can give... measurements are 48w 37h1 35.25h2 38depth with .75 material.
Link to calculator I used
Subwoofer Enclosure Calculators, Fraction to Decimal, Parallel, Series, Port Length and Volume Calculators
Old 05-01-2011, 11:26 AM
ltr450racer690's Avatar
0/11 sssss3414
with that big of box and only using .75 wood, ur going to flex really bad even if braced. i would of double up the box at min...
AUDIOTECHIX DEALER
DLP CUSTOMS SALES REP
Old 05-01-2011, 11:39 AM
macisme's Avatar
Team Sundown FTMFW!
0/11 sssssss16
I can do that. Good idea btw. I didn't even consider that, though im sure I would have noticed it later. The baffle was planned to be double thick, but I just didn't consider the rest of it since its so close to the metal in my truck.. I can get more wood on most of the outter sides of the box, but not in the corners since its touching every corner to the body, but it can't much closer then how I'll have to build it. Also we were going to basically build a frame inside the box from angle iron and bolt the wood to it.. only problem with that is tons of drilling and bolting
Old 05-01-2011, 12:18 PM
0/11 sssss3414
i understand what u mean. i use a 2x4 shell on my wall and then birch onto that. if you needs help i live in west lafayette and could help out if needed
kyle
AUDIOTECHIX DEALER
Old 05-01-2011, 12:56 PM
macisme's Avatar
Team Sundown FTMFW!
0/11 sssssss16
kyle
Thanks for the offer. I'll keep you in mind if I run into any snags that stump me
Port size for 2 sa-10s in 3cu. box [email protected] Enclosure Discussion & Design Construction Help 5 04-11-2011 10:47 PM
help figuring out port? yukon Enclosure Discussion & Design Construction Help 3 05-13-2010 09:08 PM
Need help with port size nastyone Enclosure Discussion & Design Construction Help 2 02-20-2010 11:45 AM
Box and Port size RD HW 18 Drock040687 General Car Audio Discussion & Questions 44 11-28-2009 06:12 PM
Port Size BassikInstincts Enclosure Discussion & Design Construction Help 10 03-30-2009 07:19 AM
