Ideas for a sub forward port foward trunk box. 2 15"s - Car Audio Classifieds!
Old 05-04-2011, 08:23 AM
Kian_NJ's Avatar
Awaiting Confirmation
0/11 sssssss94
Default Ideas for a sub forward port foward trunk box. 2 12"s
So after spending 2 hours in Google sketch up i gave up (anyone know how to change the settings for a different unit of measurement, I clicked the wrong one). I have 2 15" BTL's and i wanna do a sealed Sub forward port forward trunk build @40hz. I was wondering if anyone had any suggestions on the location of the port. The double will be double layered 3/4"MDF only the top plate of the box will be single sheet. i have mdf already attached to the upper part of my trunk.The subs will see around 8kw.
These are the Maximum dimensions:
Port idea for the middle of the box:
I Also have 8" aero port/sewer pipe
Any ideas? or is this just not going to work?
09 Honda accord
2 sa8-v2 Batcap 400JVC KW-AV70BT
##Sold (2) C&D Technogy batteries (1) optima yellow top up front (1) batcap 400 (1) Saz3000d (1) 15" Fi frankenBTL (1) Mechman 270....15x.x out of my trunk
Old 05-04-2011, 08:35 AM
0/11 ssssss954
port either in middle or 1 on each side
Old 05-04-2011, 08:52 AM
Kian_NJ's Avatar
0/11 sssssss94
Do you think i can get a big enough port in the middle?
09 Honda accord
Old 05-04-2011, 09:02 AM
0/11 ssssss954
yep. ive seen boxes walled at the trunk like that with 2 xl 15's and a total of 6 small aeroports in the middle
Old 05-04-2011, 10:02 AM
Kian_NJ's Avatar
0/11 sssssss94
If i can fit it ill try it. Im just uncertain how big the spacing will be between the woofers.
09 Honda accord
Old 05-04-2011, 10:12 AM
0/11 ssssss954
4 inches with that design
Old 05-04-2011, 10:50 PM
Kian_NJ's Avatar
0/11 sssssss94
I don't think 4" will have enough port area.
09 Honda accord
Old 05-05-2011, 12:35 AM
SketchUp Master
0/11 ssssss417
I don't see this being possible.
Old 05-05-2011, 07:24 AM
CLNFREAK's Avatar
0/11 sssss1788
Feedback Score: 23 reviews
My box is 36w 16h. For two 12" and an 8" aero
I don't think you will be able to find enought room for the amount of port you need
MAY 8 2009 ask me about that day !!!!
SUBS (2) 12" DC LVL 5
SUB AMP 1100.1
MIDS AND HIGHS AMPS 2 EXL 400.4
BATTS NSB group 31, XS power d3400
SINGER ALT 350 AMP
TEAM DC
DCSOUNDLAB.COM
SINGERALTERNATORS.COM
Old 05-05-2011, 07:28 AM
0/11 ssssss954
Ya man you can put 2 or maybe 3 4 inch aero ports
Ideas for my trunk build Legendary754 Enclosure Discussion & Design Construction Help 2 08-13-2011 06:58 PM
Ideas for box for two DD 9515's in 93 Continental trunk...? westman995 Enclosure Discussion & Design Construction Help 16 01-01-2010 05:19 PM
Forward vs Rear firing In trunk ascitiesburn69 Enclosure Discussion & Design Construction Help 21 09-23-2009 04:14 PM
Patrick's CACO amp rack and trunk panel ideas Patrick Simmons Enclosure Discussion & Design Construction Help 31 01-18-2009 05:19 PM
