What do you think? - Car Audio Classifieds!
Old 05-07-2011, 12:37 AM
Ajax_6154's Avatar
i want more bigger db's
0/11 sssss2369
Default What do you think?
well do to me changing my mind every 5 minutes and some unforseen circumstances (wife totalling the MINI) i now have to settle with a temp setup until i can save up the money for a big build. so im thinking 4 SA8's on hopefully an AQ2200d if i can find one. here is the box. it will be a center console box with the port firing into the rear passangers side door. im thinking of doing some red l.e.d's in the port and inside the box with the subs mounted on 3/4 plexi with a beauty ring.
does anyone think that the plexi wont hold up or its a bad idea? let me know any opinions will be appreciated.
Ajax
Vehicle: 2011 VW GTI Autobahn
Deadning: 50sq ft of AT 60, Front Stage: CCX65 on a 1000c4, Sub: Eminent Audio EA1000 10's in 4.9ft3 at 35hz on a BC3500d at 1ohm
i dont like 12's they cant hit the lows like 10's
Old 05-07-2011, 12:48 AM
Dunbar91's Avatar
0/11 sssss6816
Feedback Score: 51 reviews
i would do something to support the weight, thats 100 pounds on the plexi
Old 05-07-2011, 12:54 AM
Ajax_6154's Avatar
0/11 sssss2369
yeah been thinking that too maybe a thread rod in the middle if i can create a gap in between the center 2 subs
Old 05-18-2011, 07:53 AM
Ajax_6154's Avatar
0/11 sssss2369
bump
