1st BLOWTHREW BUILD - Car Audio Classifieds!
Old 05-07-2011, 06:02 PM
0/11 ssssss446
Default 1st BLOWTHREW BUILD
I am going to be helping my friend out with his BLOWTHREW in his 1994 GMC 1500 Ext.cab .. wanting to no wat all is involved and box suggestions we are using 4-SA12s and a SAZ3500 or M3 (DD) amp to push em .. all help will be great including wat materials we will need and wat to watch out for .. thanks
Old 05-07-2011, 06:06 PM
0/11 ssssss954
subbed cuz im wanting to do this also
Old 05-07-2011, 06:15 PM
0/11 ssssss446
info such as ft^3 for the box ... port area .... box type (4th order / regular port / etc.) / sub orient. / hes willing to use ALL of bed if needed.. wants it to play music not stictly SPL setup ... just a bang n daily ..lol.. thanks again
Old 05-08-2011, 12:59 AM
0/11 ssssss446
anyone
Old 05-08-2011, 11:08 AM
SketchUp Master
0/11 ssssss417
I'd do a bandpass setup so you can easily fire all of the sound waves into the cab via the port. 4ft^3 sealed and 8ft^3 ported tuned to 48-50hz should do the trick. What kind of dimensions are you working with? I figure he has about 49" or so between the wheel wells, so you're probably going to have to angle the sub baffles inside the box into a V shape to get everything to fit.
Old 05-08-2011, 11:12 AM
ltr450racer690's Avatar
0/11 sssss3414
yep agree with it all, i personally would do 44-50hz tune but its all up to you
kyle
AUDIOTECHIX DEALER
DLP CUSTOMS SALES REP
Old 05-08-2011, 11:32 AM
SketchUp Master
0/11 ssssss417
kyle
Yeah, just depends on what he's going for. A 44hz tuning would definitely make it more of a low-end monster...great for demos.
Old 05-11-2011, 07:48 PM
0/11 ssssss446
thanks for the info... i will post measurements 2moro.. and yes ill def, have to angle them like a V to fit 4-12s......and i want this to be a music vehicle yes id like to c 150+ db but i want it to pound on music 1st & for most ,... so wat should it be tumed to ??
Old 05-11-2011, 11:46 PM
SketchUp Master
0/11 ssssss417
Depends what you mainly listen to. If you mainly listen to Decaf sort of stuff, then a lower tuning will do you good.
Old 05-11-2011, 11:52 PM
0/11 ssssss446
Not sure wat DECAF sort of stuff is ?? but i listen to rap music NOOO chopped and screwed or slowed down or BASS added to the music garbage..lol but like ...walk with a waddle / juicebox / young jeezy them kind of LOWS .... so let me no wat u think..
Tags
blowthrew, cut through, digital designs, sa12, sundown
CLNFREAK'S build... rebuild.... build... CLNFREAK Build Logs 43 06-26-2012 06:25 PM
S-10 truck build and blow-through build DevinG17 Build Logs 82 02-16-2011 01:58 PM
Story of my 18 build (first real build) TheAustinHenry Car Audio Videos 35 12-20-2010 12:04 AM
SPL_II's Team CACO Build Log <--- First real Build! SPL_II Build Logs 123 09-23-2010 08:44 PM
deepsilencer's new box build video designed by james(A.I),build by 99s10walled deepsilencer Car Audio Videos 1 08-30-2010 01:43 AM
