another complicated design - Car Audio Classifieds!
Old 04-01-2009, 08:41 PM
Default another complicated design
since I need a new box and I think 18's are little much for no wall I designed this
7ft tuned to 30hz
128" of port opening up to 320" of port
2 15's port back sub back
should be pretty solid
either want to use
jbl gti's
soundstream splx
or RExxx
Old 04-01-2009, 08:43 PM
Prohibited Sellers/Buyers
0/11 ssssss327
you have to be careful any time you have smaller chambers in an enclosure because pressure is going to be insanely high there.
Which will increase back pressure on the woofers...but it does look pimp just not sure how well it would work vs just a well built ported enclosure
Old 04-01-2009, 08:45 PM
yeah I know how that is I have destroyed boxes before but steel and fiber glass should be enough to hold it together I'm only running 5000 through it I would love to double baffle it all but no room for it and I also use birch not mdf
Old 04-01-2009, 10:23 PM
well I already improved it when I was looking in my car and can drop the height from 21 tall to 16" tall which makes it way better to see over
By wenn_du_weinst at 2009-04-01
Old 04-01-2009, 10:25 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
your designs are always cool.
92 Ranger Walkthrough
(Under Construction)
Old 04-01-2009, 10:26 PM
thanks to bad people always want to build a simple box they always look better following the contours of the car
Old 04-01-2009, 10:29 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
im glad we have blazers, i could use your designs lol.
Old 04-01-2009, 10:30 PM
bones22's Avatar
0/11 ssss12257
very true
only problem is sometimes that mean NASTY angles inside it that restrict flow
Old 04-01-2009, 10:31 PM
Originally Posted by bones22 View Post
very true
yeah this last one shouldn't be that bad now I just gotta find the right 15's for it tuned at 31 hz so it should get low
Old 04-01-2009, 10:33 PM
bones22's Avatar
0/11 ssss12257
for the $ im sure you can find some probably NEW
Cadence wild beasts. they would do well
Box design anyone? Buddah_iii Enclosure Discussion & Design Construction Help 5 02-04-2009 09:53 PM
complicated box design- like challenges? upzaw2000 Enclosure Discussion & Design Construction Help 60 12-28-2008 02:21 AM
my design korey_hofer General Home Audio/Video 9 12-26-2008 08:58 PM
Need help with my box design thecartel Enclosure Discussion & Design Construction Help 10 12-12-2008 07:02 PM
Can Someone design this for me. worstenemy453 Box Requests 7 11-12-2008 06:31 PM
