dumb question but im sure an easy answer - Car Audio Classifieds!
Old 05-11-2011, 12:14 PM
0/11 ssssss155
Default dumb question but im sure an easy answer
hey guys i am messing around with the torres box calculator and am planning on adding an extra baffle to the box (sub on top) to strengthen it up. it has an option to insert number of extra baffles used so i put 1 extra baffle. this makes the net volume .30 cubes smaller and changes the port area range. how does this work? i am only going to add another piece of .75 inch mdf on top which wouldnt really mess with the inner displacement right? except for pulling the woofer out an extra .75 of an inch? sorry dumb question!
Old 05-11-2011, 01:59 PM
0/11 ssssss155
here is what i came up with..any suggestions? sub is a psi built 18'' pushed by about 1500rms. want it to get low and still sound good with daily listening. thanks guys
Old 05-11-2011, 02:13 PM
Wheres The Butta's Avatar
0/11 sssss6101
Feedback Score: 21 reviews
because you're still listing the same outside dimensions.
If you want an extra baffle, change the external dimensions to reflect that.
____________________________________
IASCA Pro AM and MECA Modex -->
Old 05-11-2011, 02:21 PM
Ajax_6154's Avatar
i want more bigger db's
0/11 sssss2369
^^^^^ THIS
Vehicle: 2011 VW GTI Autobahn
Deadning: 50sq ft of AT 60, Front Stage: CCX65 on a 1000c4, Sub: Eminent Audio EA1000 10's in 4.9ft3 at 35hz on a BC3500d at 1ohm
i dont like 12's they cant hit the lows like 10's
Old 05-11-2011, 02:37 PM
0/11 ssssss155
thanks guys..now the building can start!
probably a dumb question but quick question about pollyfill mattintc10 General Car Audio Discussion & Questions 15 05-05-2012 04:46 PM
Need help getting answer on battery question. brandon_s0854 General Car Audio Discussion & Questions 3 03-15-2011 07:35 PM
Need a answer to this question please! DntULuvMe General Car Audio Discussion & Questions 5 08-14-2010 03:24 PM
Maybe an easy question DeltaOn4's General Car Audio Discussion & Questions 9 05-31-2010 05:54 PM
Very Quick Easy Question Bologna General Car Audio Discussion & Questions 3 03-06-2010 11:45 AM
