Help with port - Car Audio Classifieds!
Old 05-16-2011, 06:17 PM
0/11 ssssss216
Default Help with port
I have two 15 inch LVL 4 15's with LVL 5 soft parts on Crescendo 3 WKP, the subs are in a 07 impala. when i built the box there in now i built the box on the small side it's rite at 6 cubes net tunned to 32 with four 4" aero ports, now i know that this is really not enough port area for these subs especially since there in such a small box but i didn't have enough room to fit the six 4" inch ports i originally was going to use. The ports are firing through my rear deck subs firing in the cabin, what i was thinking about doing is replacing the aeros with a square/ slot port but i'm not sure how to calculate the size port i would need, was hoping that someone would be able to help me figure this out to see if i have enough room to do this I have a wedge type box but this is the what i have to work with from top of box to rear deck 36"w x 27.5" D x 15"H ( 4" from top of box to rear deck) keeping in mind would want to keep as much port externally as possible. thanks in advance for any help given.
round port converted to square port Ryan1126 General Car Audio Discussion & Questions 4 04-12-2010 03:46 PM
