I want someone to build me a fancy amp rack - Car Audio Classifieds!
Old 05-18-2011, 09:59 AM
Jdubs04ss's Avatar
0/11 sssss1561
Default I want someone to build me a fancy amp rack
I am looking for someone to build me an amp rack which will consist of MDF,plexiglass,leatherwrapping the MDF and cutting holes for the wires and using grommets so it looks clean. I will send you a cardboard 1:1 ratio size of the bottom MDF so there's no question the size and or where the holes for the wires need to be cut...
Question is...Are you man enough? Lol jus playing but forreal who can build this lol
Sent from my DROID2 GLOBAL using Tapatalk
2004 Impala SS
240amp Alt,XP3000s,BIG 3,1/0,Alpha Damp
Pioneer AVIC-X940BT
Digital Designs M3a(3 of them) & SAZ-2500d
18" Crossfire XS V.2 / 15" DC XL m2 D2
Need DC 270xp,320xp or bigger alt
Old 05-18-2011, 10:19 AM
Team Retribution-DJ's Avatar
0/11 sssss1934
Sounds like a very easy project ..
TEAM XS POWER -TEAM MECHMAN
Old 05-18-2011, 11:17 AM
Jdubs04ss's Avatar
0/11 sssss1561
Not for me lol I dont have the tools to do it and Im having the hardest time trying to figure out what this one certain part is called. Ok I want the MDF on the bottom then the amp on top of that and then I was the plexi on top but I dont want it inclosed. I just want for lack of a better word..a Plexiglass or fancy looking peg type leg for each corner of the plexiglass so this way the amp can breathe all the way around but yet prevent as much dust or anything getting on top of the amp and/or scratching it..I might want to do both pieces as ovals if it isnt too much more or at the least round the corners of the MDF and plexi...My one problem is finding somewhere to put it. The only place I can think of is attached to the back of my box so then Id also need some sort of vibration absorbition mat to stick on the bottom of the MDF. Or actually if Im gonna attach it to the box then I would need another 4,6 or 8 (however many) 3/4" legs underneath that because I forgot that I would need the wire to run under it
plexi on top
______________
l ampamp l
l ampamp l <pegs or legs on each of 4 corners
---------------- <MDF
l l <3/4" tall pegs with absorb matting under each one to attach 2 box
and be able to run 1/0 wire underneath
2004 Impala SS
Pioneer AVIC-X940BT
Old 05-18-2011, 11:20 AM
0/11 ssss31247
you might want to do a sketch of what you are looking for.
If I were building it based on the info you've provided... you'd get a flat piece of MDF covered in stuff {leather like material} with holes in it.
Seems you might want something a little nicer.
Old 05-18-2011, 11:29 AM
98GMC's Avatar
0/11 sssss1265
Are you wanting a plexi trim panel to surround the amps to make it look flush?
Old 05-18-2011, 02:41 PM
Jdubs04ss's Avatar
0/11 sssss1561
HAHa yes! its exactly what i'd like lol I said I could send a sheet with the stuff on it to whoever wants to built it..I'll draw something up in photoshop while im "working" lol
Can you eloborate a little more? I was talking about having plexi on top pretty much sammichin' the amp inbetween the two but then have pegs on the corners to kinda hold the plexi up a little bit higher than the amp so its not touching
2004 Impala SS
Pioneer AVIC-X940BT
Old 05-18-2011, 03:11 PM
Jdubs04ss's Avatar
0/11 sssss1561
Heres a quick sketch up..Does this make it easier to visualize it?
2004 Impala SS
Pioneer AVIC-X940BT
Old 05-19-2011, 09:47 PM
Jdubs04ss's Avatar
0/11 sssss1561
Anyone
2004 Impala SS
Pioneer AVIC-X940BT
Old 05-19-2011, 09:51 PM
0/11 ssssss850
seems to be a cool idea, lol simple but i myself couldnt do it either but gl let me know if you find someone i may have them build me one too
2 DC XL 15's, Sd5k
7.56 cubes after displacement
270 mechman alt, 1 deka up front, 1 c and d
Old 05-19-2011, 10:06 PM
More spl's Avatar
0/11 sssss2638
Feedback Score: 29 reviews
Here's what I'm getting out of it If you mount it to the back of the box how you gonna pull the wires through the holes?
What type of material is the fancy material you want? You gonna want leds or light bulbs to light the amp up.
Obviously you want to boarder the plexi are you gonna want to e able to remove the plexi to adjust or you only want 4 mounts?
Whats the total demensions that will fit length width height?
Is there a specific color you require?
Are you gonna run interior amps and where will they be on this rack or in a different location?
Sorry just you have to answer these questions or It will probably turn into thats not what I wanted or why doesn't it fit Or I don't like the color Its canary yellow lol.
this how I feel about audio
http://www.youtube.com/watch?v=8th2J3c88mU
OT: server rack build gcsviii Build Logs 18 05-14-2011 10:02 PM
Rack Em' Rack Willie Oldbass38 Off Topic Chat 3 04-13-2011 09:27 PM
SA-8 single vs. double spider pack testing (with fancy graphs!) tommyk90 (Sundown Audio) 18 08-27-2010 03:30 PM
"fancy" restaurant ideas Bobby32 Off Topic Chat 40 05-12-2010 06:13 PM
Need Ideas for Amp Rack and Battery Rack! BassikInstincts General Car Audio Discussion & Questions 8 01-15-2009 10:36 AM
