Ported box for Two 1508's. Where to put the port? - Car Audio Classifieds!
Old 05-18-2011, 05:34 PM
0/11 ssssss639
Default Ported box for Two 1508's. Where to put the port?
I am currently running two 1508's in a transmission line, and it sounds alright, but I know these puppies will get down more in a ported box. My question is:
Should i mount both subs side by side, and put the port next to them? or should i put a port between the two subs?
Old 05-19-2011, 11:23 AM
98GMC's Avatar
0/11 sssss1265
Common chamber with 1 port with woofers side by side as far from port throat seems to work best. I like side firing with smaller drivers.
Old 05-19-2011, 11:53 PM
0/11 ssssss639
i was thinking that too. Or an aero. What kind of tuning would i be good with for spl on two 1508s?
Old 05-20-2011, 12:15 AM
0/11 sssss2649
DD subs love large boxes and large port area. I had (well still have 1 left) 2 1508 supercharged in a 2.5 cu ft box after displacement (yes a little bigger then DD specs) tuned to 35 hz. And I was doing hi 139's and 140's on music on a DD m1b amp. I was fairly flat from 130-140 hz within 1.5 db's. SQ was amazing!! Personally I love the lows and wanted a low bass monster from 8's and that's what I got in my trunk car (Lexus is 300).
When u said SPL I doubt u meant u r planning on competing? If u want a loud daily driver I would recommend either 2 4's or 1 6" aero port tuned between 36-40 hz and build ur box between 2.0-2.5 cu ft after displacement. Don't forget the precision port calculator doesn't subtract for driver and port displacement. Basically if they don't sound very impressive something is wrong.
Old 05-20-2011, 12:18 AM
0/11 sssss2649
Also if ur interested in the DD m1b or 1 1508 SC D4 pm me.
Old 05-21-2011, 02:50 AM
0/11 ssssss639
I was plannig on doing a 2 cube box (after displacement) with either two 4" aeros or one longer one. How would one calculate for two 4" aeros? Find the surface area of one, double it, and reverse the equation and treat it like (guessing) one 5.25" port? I've never worked with aero ports before.
Old 05-21-2011, 04:16 AM
Ajax_6154's Avatar
i want more bigger db's
0/11 sssss2369
Subwoofer Enclosure Calculators, Fraction to Decimal, Parallel, Series, Port Length and Volume Calculators
that should help you out. also 2 4" aeros in a 2 cube box gives you 25sq inch of port or 12.56 per cu ft. 1 6" aero gives you 28.27 sq inches so 14.13 per cubic ft. if your looking for 2 cubes after all displacement (which you should) either way you go your ports are going to need to be about 21 inches lng. personally id go with a flared 6" at 22.9 inches to get 38 hz tuning here is ppi's calc just less around with it. Products Menu
Vehicle: 2011 VW GTI Autobahn
Deadning: 50sq ft of AT 60, Front Stage: CCX65 on a 1000c4, Sub: Eminent Audio EA1000 10's in 4.9ft3 at 35hz on a BC3500d at 1ohm
i dont like 12's they cant hit the lows like 10's
Box for 2 DD 1508's quaddropper Enclosure Discussion & Design Construction Help 4 09-05-2010 01:18 PM
[SOLD] 1508's TaylorFade 8" Subwoofers 7 06-09-2010 04:35 AM
1508's? All they're craked up to be? BASS_WARRIOR General Car Audio Discussion & Questions 22 01-19-2009 12:45 AM
DD 1508's for sale spluvs2install Recycle Bin 0 08-06-2008 11:00 PM
